Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
Unable to View Java Applet
Java Plug-in 1.6.0_11
Using JRE version 1.6.0_11 Java HotSpot(TM) Client VM
User home directory = C:\Users\Administrator
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
o: trigger logging
q: hide console
r: reload policy configuration
s: dump system and deployment properties
t: dump thread list
v: dump thread stack
x: clear classloader cache
0-5: set trace level to
load: class JFI.class not found.
java.lang.ClassNotFoundException: JFI.class
at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed:https://'here client link"/cyberdocs/applets/JFI/class.class
at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
... 7 more
Exception: java.lang.ClassNotFoundException: JFI.class
I have connected SSL VPN and opened client link.after that when i click particular tab like "Advanced" it's showing as blank white page with top right corner as cross mark.When i check this Java log file,It's showing as the above error.
Kindly request you to resolve this issue. It's urgent!!!
Thanks in advance.
Noorul Ameen.A
  • Donald Blake
    Donald Blake Mar 11, 2009
    i cannot open the yahoo pool game
  • 61 Answers
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
Posted on Jan 01, 2009
How can i corredt this error ??
report to mojang and play the pe version for a while. or you can delete your minecraft file and download it again
May 23, 2014 | Kaltner.net Minecraft Mobile Admin
DOD sites will not recognize that my pc has JRE 1.6 installed
im using windows 8 and installed, removed and re-install it and nothing works.
Dec 12, 2013 | Computers & Internet
Google try google
If you browse java.com and find the update you require, clicking on it will install it for you.
Dec 03, 2013 | Computers & Internet
I am using a macbook running os x 10.6.8. i going nuts trying to view images of documents on courts domainweb website. There are 2 choices to view, save or print case files in .tiff or java and i can NOT...
If you are using Safari web browser click on "Safari in the top toolbar on the left side. go to "PREFERENCES" / SECURITY / Web Content
check the box to "ENABLE JAVA SCRIPT"
Sep 06, 2013 | Computers & Internet
E2020 login keeps asking for java which is already installed
You must be logged in as an administrator. If prompted for your administrator password after a command, enter it and then press the Return or Enter key.
  1. Open Terminal, located in the Utilities folder.
  2. Enter this command, then press the Return or Enter key:
    sudo mkdir -p /Library/Internet\ Plug-Ins/disabled
  3. Enter this command, then press the Return or Enter key:
    sudo mv /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin /Library/Internet\ Plug-Ins/disabled
  4. Enter this command, then press the Return or Enter key:
    sudo ln -sf /System/Library/Java/Support/Deploy.bundle/Contents/Resources/JavaPlugin2_NPAPI.plugin /Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin
  5. To re-enable Java SE 6 Web Start, enter this command, then press the Return or Enter key:
    sudo ln -sf /System/Library/Frameworks/JavaVM.framework/Commands/javaws /usr/bin/javaws
Additional Information The following steps will undo the above commands and restore Java 7.
  1. Disable Java SE 6 Web Start opening:
    • Enter this command, then press the Return or Enter key:
    • sudo ln -sf /System/Library/Frameworks/JavaVM.framework/Versions/Current/Commands/javaws /usr/bin/javaws
    • When prompted, enter your administrator password, then press the Return or Enter key.
  2. Re-enable the Java 7 applet plug-in bydownloading and reinstalling the latest version of Oracle Java 7 JRE.
Important: Mention of third-party websites and products is for informational purposes only and constitutes neither an endorsement nor a recommendation. Apple assumes no responsibility with regard to the selection, performance or use of information or products found at third-party websites. Apple provides this only as a convenience to our users. Apple has not tested the information found on these sites and makes no representations regarding its accuracy or reliability. There are risks inherent in the use of any information or products found on the Internet, and Apple assumes no responsibility in this regard. Please understand that a third-party site is independent from Apple and that Apple has no control over the content on that website. Please contact the vendor for additional information.
Apr 25, 2013 | Computers & Internet
In minecarft what does this mean: hs_err_pid#
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Jan 22, 2013 | Microsoft Corporation Xbox 360 Live...
Java problem
Update to the latest version of JAVA.
Try again.
If you would like to submit a bug report, please visit:
http://java.sun.com/webapps/bugreport/crash.jsp
and submit a report.
Aug 25, 2008 | Computers & Internet
JAVA multiple programs on disk
no you don't. Just keep the most recent version.
May 04, 2008 | Sun -115H Computer Speakers
Java (TM) Plug-in fatal error
To view this page curectly intall java virtual machine pc destop of window xp operative system.
Mar 16, 2008 | Dell Microsoft Windows XP Home Edition
ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
1,019 people viewed this question
Top ArcMedia Computers & Internet Experts
Computer Links
Alun Cox
Robin Hill
Robin Hill
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
