Question about Amana ACF3325AS Dual Fuel (Electric and Gas) Kitchen Range
Amana ZRTC8500 F0 problem after a minute or two when top element
The FO problem goes on after a few minute sof the element being turned to on. Cancel cleras it but it appears again afte r1 miunte or 2.
I turned off the power fuse for 5 minutes and tried again to see if it will come up again. It did. can you help?
  • Sherry Leach May 17, 2009
    My model is zrtc8500ww
    I walked into the kitchen and noticed the "F0" code on the panel.
    Nobody had used the stove top or oven since last night. If I press oven
    cancel it goes away for a minute or 2 then returns. My manual does not
    show me an "F0" error code!
4 Suggested Answers
SOURCE: F1 service code
The owner's manaual states that F1 means Control Malfunction.
The manual recommends the following:
Press Oven cancel pad or disconnecting power supply may eliminate F code. If failure continues contact an authorised dealer.
Posted on Dec 23, 2008
MNfisherman
  • 11896 Answers
SOURCE: F-9 warning with buzzer
try unplugging for a few hours. If this does not correct the problem which it should, make sure the door latch is releasing and latching when door opens and closes.
also make sure door is locked before turning to clean.
Posted on Mar 31, 2009
heatman101
  • 43501 Answers
SOURCE: Oven not lighting
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 30, 2010
Hitachi TV freezes aft viewing for few minutes. Can turn off n back on for few min then freezes again
before doing any thing check signal level,if it is low this can cause picture to pixlate or freese to test use a dvd player as a signal source ,if it plays fine its low signal level to tuner good luck, butler
Oct 02, 2016 | Hitachi Televison & Video
FO comes on as soon as you turn it on. Why
F0 code usually Frequency 0 zero try shutting it down unplug for10 minutes. Make sure it is draining properly. Also fresh batteries in remote can always be a good ides
Jul 23, 2015 | Norpole 12000 BTU Window Air Conditioner...
My simpson top loader switches off after about 1 to 2 munutes. If you turn it off and wait a few minutes will switch on again but only for a minute or so again. I opened it up and run led goes off
could be a dodge motor
or a bad lid closed switch or interlock
or some heating or drain
i think its prob something too do with the heater element
or the motor draws too much current for some reason
Dec 16, 2014 | Simpson Washing Machines
Display turns dark pink for few minutes and goes
1,the color starts to go out, it become the white and black ,
2,then,the projector running off after only a few minutes,
it is a general issue:the inductor need to be cleaned
Use a cotton swab moistened with alcohol to clean the inductor.
the inductor (Sensing element),is near to the Color Wheel.
the industor : is a black little element,as little as a sesame seed
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Oct 23, 2013 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
I keep getting FO code and beeping won't clear
Hello George,
The F0 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F0 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Oct 05, 2011 | GE Profile JKP56 Electric Double Oven
Have Error code FO, no hot water. Press reset and water gets warm for few seconds then goes off again.
1) BOSCH website shows error codes.
FO does not appear:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
2) I do not see FO error code listed on Internet search
Other FO questions at fixya seem to have no answer:
http://www.fixya.com/tags/error_f0_bosch
3) At this point, I would suggest calling a service technician.
While waiting for service, read manual cover to cover several times.
4) Your manual is valuable resource, and shows the word 'maintenance' and 'troubleshoot' frequently.
Tankless are maintenance heavy, and should be de-limed each year.
U-tube search "delime tankless water heater."
5) Also explore Bosch website for your manual and other valuable information.
6) When service tech arrives, ask that person for tips and tricks about your unit that will help you maintain your water heater.
7) All costs are energy. Install DIY tank-type gas water heater and avoid the whole headache.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Mar 08, 2011 | Bosch Water Heaters
Dryer is not heating up. yesterday the dryer would not turn on, the black wire on the cord had burned in half. bought a new cord, dryer turns on but no heat. circuit breaker was not tripped. turned it off...
These are pretty simple to fix. Take the service panel off and check the heater elementthemobilian_1392.jpg
The limits and element is all in one nice little bundle and only 2 screws to mess with.
Note: the control stat is mounted on the blower housing, these limits on the heater element only tripp if there is air restrictions.
I have your service manual right ova heah: Amana dryer tech service brochure
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2011 | Amana ALE230RAW Electric Dryer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
Amana ACF3325AS Dual Fuel (Electric and Gas) Kitchen Range Logo
99 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
