Question about Compaq Presario 5000 PC Desktop
Screen says no signal input.
I have a compaq presario 5000. When i turn it on, the screen says no signal input and says please check video signals. What can i do to fix this problem?
  • 4 Answers
Well,this probably implies a lot of problems. 1.Check the video adapter cable,make sure the pins are not bent or broken. 2. Open the case panel of the left side and disconnect and remove components such as Vga card,rams,hdd,roms,floopy drive,other agp/pci cards and wipe dust particles and on between slot then put them right back. 3. If step 2 fails,remove the vga card,video cable,hdd,processor and rams and approach a nearest friend to test the devices to see if they are working. 4. U can reduce your labour of hardware diagonising by using a POST card which observes the beep codes made by your cpu but u wil have to find out what beep codes mean(google). 5. If you find that all necessary parts are working then your motherboard is either short circuted or dead. After u have tried above solutions,rep to me confirming the status. Thank u!
Posted on Jul 20, 2011
    Scholar:
  • 141 Answers
Did you try the screen with another computer?
Did you try the computer with another screen?
Do you ear the fan running when you start?
if yes the graphis card might be dead. if you don't have a graphic card (on the mother board) CPU dead or mother board any way ...bad signs
Posted on Dec 23, 2008
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Cannot conect presario V4000 to projector
Set your screen-resolution to 800-by-600 at 60 Hz.
Then, use Fn-F4, to see if the projector accepts 800-by-600 input.
Apr 10, 2010 | Compaq Presario Notebook
My compaq desktop has two long beeps a pause and two long beeps without a signal to the monitor. If I put a recovery disk in it beeps normally but still no screen.
Sounds like a video adapter problem. Try taking your video card out and then reseating it into the PCI slot. Make sure your monitor is connected correctly. Also, it might not hurt to make sure the all other periphs are seated correctly. (RAM,Network card, etc) hope this helps
Feb 03, 2010 | Compaq Presario 5000 PC Desktop
Have hooked up Magnavox 19" tv as computer screen but don't have sound.
If the computer was connected to the Magnavox using the VGA connector you will not hear sound through the Magnavox, as the VGA connector is a video signal only. Unless you use the HDMI connector, which carries both video and audio, you may not have sound. Verify the back of the Magnavox to see if there are any audio inputs from the PC that may work alongside the VGA connection. Most televisions with a VGA connector do not have this feature as the VGA is strictly for video signal and not sound.
Sep 26, 2009 | Compaq Presario 5000 PC Desktop
NO VGA INPUT SIGNAL
hi im aleli can you give me a driver of c700 video controller,, tnx
Jan 08, 2009 | Compaq Presario C700T Notebook
Screen shows no signal
Hold down the power button for about 6 seconds continuously, this should wake it.
Sep 19, 2008 | Compaq Presario 5000 PC Desktop
No beep
What indication do you have that the system is on?
Do you have any LEDs active on the front of the system box?
Also, your monitor should indicate whether you are receiving video sync signals from the system by changing LEDs or the color of one and possibly give you an on-screen notice that it is or isn't getting input.
If you disconnect the video cable from the back of the system box, most monitors will post a small notice on the screen that it is working but not getting any input.
May 06, 2008 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 start up problem
Follow the instructions: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=96382&prodTypeId=12454&prodSeriesId=96382&objectID=bph07173
Nov 11, 2007 | Compaq Presario 5000 PC Desktop
Compaq Presario 5000 PC Desktop Logo
149 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
