Question about LG DLG2525S Electric Dryer
Power will not come on
Turned circuit breaker on and off. Power push button does not work. when door is open light comes on.
SHUT DOWN POWER AND RE START
Posted on Dec 23, 2008
Dishwasher not working after circuit breaker turned off
Circuit breaker tripped because of fault in dishwasher, which is why it no longer works. Sorry but I can not tell you what dish washer fault is.
Sep 13, 2017 | Bosch Dishwashers
Control panel buttons no longer work.
Hello ...
I tried to look up your model numbers here (usa)...
with no success... (Kenmore 13742 / 13744 / 13749)
I rarely (ever) suggest owners go direct to Sears...
but this would seem to be.. appropriate...
(I my opinion they are rude & pushy to sell parts
(good news ... here... their guaranteed fit/fix)).
Before doing so...
Check your water, drain & power at the appliance.
With the breaker turned of...
open the appliance cord JUNCTION BOX and assure the
wiring devices (usually "wire nuts") are still tight and secure.
Finding nothing... you are at the UNHAPPY JUNCTURE
where you need to use SEARS PARTS DIRECT...
http://searspartsdirect.com/dishwasher
Aug 01, 2017 | Kenmore 13742 / 13744 / 13749 Built-in...
No lights - Acts Like It Has No Power At All
see the diagram and pictorial and proceed with common sense:
1) test the fuse for open or band contact with VOM,see the diagram attached how to do it
2)check the switch door hook or door release button,when they are broken they do not touch the switch, and will NOT start. test for open
see the diagram
Jul 16, 2012 | Microwave Ovens
It does not appear to getting any electric power. no light comes on. nothing happens when button are pushed. circuit breaker ok.
most likely your door switch is faulty check this first if it is ok may be the electronic board it may have to be replaced let me know how you went remember to turn of power before you open panel
Apr 07, 2011 | Haier Dishwashers
Hi, My garage door stopped working when I tried to close it. I have Craftman 1/2H HBW0777. The Fuse went OOS. I turned it back but the opener doesn't work
sounds like the motor turning and overpowered the circuit. first you should unplug the opener test for power at the recepticle. if you have power you know its the motor. or something is caught in the track preventing the door from coming down. after you test for power.pull the release that attaches the opener to the garage door and try to manually move the door up an down. with the door still unattached look for a reset button on the back of the opener and try it without the impedence of the load of the door
Sep 30, 2009 | Electrical Supplies
The circuit breaker trips when I open the refrigirator even when the ref switch is off
There must be a short in the internal lighting circuit which have one functional component, the switch. It is usually a white push-button inside the refrigerator near the door. The door pushes the switch when it is closed turning the light off. When the door is opened, the button pops back out to turn on the light. In your case, when you open the door you are switching on the light but the circuit breaker trips off. It means the short circuit is in the light wiring and nothing else. Retrace the wiring and you'll surely find it there. Rewire and have a good day.
Sep 24, 2009 | Refrigerators
Sears Craftsman Gar. door opener won't respond
There isn't a fuse. You are going to need to remove the cover on the opener and find out where you are losing the power. Maybe a neighbor has a volt meter you could use. I would check the power cord and then the logic board. Makes no sense but I would check for burnt or missing traces on the printed circuit board especially around that small transformer.
Aug 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Dryer light comes on but unit will not power up or turn on
Check & reset breaker in breaker box.
Your problem may be you have lost one side of your voltage coming in. Light in dryer comes on but circuit to start motor is off.
Msg back if that does not work& we will go further.
Mar 11, 2009 | LG DLEX0001TM Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG DLG2525S Electric Dryer Logo
120 people viewed this question
Top LG Dryers Experts
Mike
Mike
John Tripp
John Tripp
Craig Butler
Craig Butler
Are you a LG Dryer Expert? Answer questions, earn points and help others
