Question about Viper Security and Remote Start System (basic install included)
The car would just stall for no apparent reason
Around the end of October I began experiencing the following: the car would just stall for no apparent reason. When it stalled the door locks would unlock an the instrument lights would go on. If I was going slow when this happened I would have to put the car in neutral an restart it; if I was on the highway the car stalled out the the door locks would unlock an the instrument lights would go on and the car would restart on its own, I'm sure this is due to the speed of the car at the time. I felt it had something to do with the remote starter. I returned to where it was purchased. They checked it and felt that they could not confirm what the problem might be. Well it's been about seven weeks and the car has been fine. It may have been a short or something that they unknowingly touched, which corrected the problem. Anyway the problem has returned. Do you have any ideas what the problem could be? We have several of these units on various family cars and never experienced anything like this. please advise,
  • djackv Jan 08, 2009
    It was the ignition. Thanks
    Problem Solver:
  • 8 Answers
Finaly had to replace the ignition swich on my S10 Blazer, that solved my problem , that was after Circuit City said they had no idea what the problem was, they worked on it every week , until I figured what was wrong with it.
Posted on Jan 07, 2009
Engine stops while travelling for no apparent reason , temp normal , restarts after a few minutes
6 common reasons are, bad battery,fuel pump,moisture in the gas, bad wiring,low fuel pressure,distributor cap. all the links below give more detail. press the helpful button
Fix Your Engine Stalling While Driving Like Pro Pictures
Solving Intermittent Stalling Problems
Diagnose Engine Stalling Problem
Jan 29, 2016 | Cars & Trucks
I have a land rover freelander 2002, the window from the tail gate door goes down by itself and stays down. The window goes up fine but when it closes all the way up, comes right back down. This problem...
I've had something like this happen a couple of times.
The cure in both instances (and probably will be in yours) is the 'recalibration' of the window lift system.
It IS in the user handbook, but here is the procedure anyway.
1 Ensure the tail door is closed, the vehicle unlocked and the alarm disarmed.
2 On 3 door models, ensure the roof is on (hard back) or lowered and secured (soft back).
3 With the ignition on, use the console switch, or the vehicle key in the tail door lock, to raise the window until the
motor stalls with the window fully closed.
(the holding the switch on until the motor 'stalls' is the key thing - you MUST allow the motor to stall)
4 Switch off the ignition.
If the calibration procedure is unsuccessful, the CCU will sound a warning for approximately 0.8 second and fully lower
the window.
Tail door window calibration can fail for the following reasons:
l Window stops before minimum travel is achieved.
l Window does not achieve a stall.
l Window request removed before stall is achieved.
l Tail door opened while driving window up.
Oct 01, 2013 | 2002 Land Rover Freelander
Automatic 2004 BA Falcon stalls while driving
IT MAY BE WORTH CHECKING YOUR IN LINE FUEL FILTERS AS I HAVE EXPERIENCED A SIMILAR PROBLEM WITH MY VAN ,ONCE I REPLACED THE FILTERS PROBLEM NEVER AROSE AGAIN FOR SOME REASON THESE ALWAYS SEEM TO BE OVERLOOKED BY THE SERVICE TECHNICIANS
Jun 06, 2013 | Ford Falcon Cars & Trucks
Engine stalls when foot not on gas pedal
sounds like a large vacuum leak to me possibly a bad mass airflow sensor but i would pinch off vacuum lines maybe spray a little carb spray around throttle body and intake area to try and locate any vacuum leaks
Jul 12, 2010 | 2003 Chevrolet Malibu
Hi, I have a 2004 Buick Rendezvous CXL. I brought my car to Budapest, Hungary so have no access to experienced Buick mechanics. My local mechanic has successfully diagnosed and fixed my Rendezvous'...
Is your check engine light on? If not Seem to me that is a fuel related problem. How many miles on the car . Has the fuel filter been change? The fuel pump may be losing pressure. That will make it do that.
Jul 15, 2009 | 2004 Buick Rendezvous
PONITAC GRAND AM 1999/ STALLING SMELLS OF BURNING GAS
White smoke tells me that you have entered the land of "blown head gasket" Is temp normal and coolant full? If not, you are definitely there. Job is not difficult for a reasonably experienced tech, if you're not, either get a manual and follow instructions very carefully, or, bring it to a reputable shop. Parts are under 300... Don't forget to replace cylinder head bolts (they might look OK but are not to be re-used.)
Dec 28, 2008 | Mazda RX-8 Cars & Trucks
1992 GL Volvo 940 stall problem
check your crankcase position sensor i dont know the exact location but can check into it
Dec 23, 2008 | 1992 Volvo 940
Open Questions:
Viper 4806v won't program I am trying to install a viper 4806v two-way remote start/keyless entry in my automatic 2004 toyota camry LE 4cyl. I got the lock/unlock, horn, lights to work, and trunk pop to work. I can't seem to get the remote start to work. When I press the remote start button on the remote keypad, the car does not start and the headlights flash 7 times. Troubleshooting says 7 flashes mean a manual transmission mode error. This means I have to enter programming menu 3 and change the starter to automatic mode. When I follow the directions to get to menu 3, nothing happens because I cannot get to menu 3 when I hold down the control button after turning the ignition off. In other words, the control button is not working. The neutral switch is on like it is supposed to be. Kind of bummed about this. Could use some guidance. My wiring goes accordingly and this car does not have an immobilizer because I used a regular metal key to start it. This car has no alarm, just a stock keyless entry, trunk release, and panic button. Again, the problem is :The remote start comes in default manual transmission mode so I have to switch it to automatic transmission mode but I can't seem to enter programming. When I try to enter programming with the procedure followed using the control button, nothing happens. It does not chirp and the LED does not blink. I also cannot enter valet mode using the control button. When the car is locked, the LED blinks and stop blinking if car is unlocked ignition is turned on. I do not understand what is going on. VIPER 4806V Wires --->Camry Wires Main Harness 6pin connector H1/1 Red 12volt input (+) --> (+) White/Red at ignition Harness H1/2 Black Chassis Ground (-) --> Car Frame (-) H1/3 Brown 200mA Horn Output (-) --> Green/Black (-) at steering column H1/4 White/Brown Light Flash Isolation Wire --> NOT USED H1/5 White Light Flash --> Hazard Light Flash Relay Lt. Green Black wire (-) H1/6 Orange Ground when armed --> NOT USED Door Lock 3 pin connector 1 Blue 500mA Unlock Output (-) --> Blue Wire (-) white connector at driver kick panel 2 Empty --> NOT USED 3 Green 500mA Lock Output (-) --> Blue/Yellow wire (-) blue connector at driver kick panel Auxillary/Harness 24 Pin Connector 1 Pink/white 200mA Ignition 2 output/ Flex output (not used) --> NOT USED 2 Blue/White 2nd Status/Rear defogger output (-) --> NOT USED 3 Red/White 200mA Trunk Release Output (-) --> 5pin Relay Pin 85 (86 & 87 to +12V, 87a White/blue trunk wire toward dash, 30 white/blue trunk wire toward trunk) 4 Black/yellow 200mA Dome light Output (-) --> NOT USED 5 Dark Blue 200mA Status Output (-) ---> NOT USED 6 White/Black 200mA Aux 3 Output (-) ---> NOT USED 7 White/Violet 200mA Aux 1 Output (-) ---> NOT USED 8 Orange/Black 200mA Aux 4 Output (-) --> NOT USED 9 Gray Hood Pin input (-) ---> Installed at hood and Switch is open when hood is closed 10 Blue Horn input (Jumper set (-)) --> Green/Black (-) at steering column 11 White/Blue Activation Input --> NOT USED 12 Violet/White Tachometer Input --> Black/Orange wire on the Datalink Connector 13 Black Neutral safety/Parking Brake Input (-) ---> (-) Ground to metal frame of car. 14 Green/Black 200mA Factory Alarm Disarm Output --> NOT USED 15 Green Door Input (-) --> Red/Black Wire (-) (Door open indicator on dashboard) 16 Empty --> NOT USED 17 Pink 200mA Ignition 1 Output (-) --> NOT USED 18 Violet Door Input (+) ---> NOT USED 19 Violet/Black 200mA Aux 2 Output --> NOT USED 20 Brown Brake Shutdown input (+) --> Green/White Wire (+) at brake switch above brake pedal 21 Violet/yellow 200mA Starter Output (-) ---> 5 pin Relay pin 85 (Pin 86 & 87 is +12volts, Pin 30 black/yellow starter wire (+) at pin 8 in ignition harness) 22 Gray/Black Diesel wait to start Input (-) --> NOT USED 23 Orange 200mA Accessory Output (-) --> NOT USED 24 Green/White 200mA Factory Alarm arm output (-) --> NOT USED Remote start 8 pin Connector 1 Red/black 12v Constant Input for Acc and starter relay (+) ---> White/Red wire 12v (+) at ignition harness 2 Pink/black Flex relay input 87A key side (+) --> NOT USED 3 Pink/white Ignition 2/ Flex Relay output (+) --> Black/yellow pin 4 at ignition harness 4 Red 12V constant input for ignition 1 Relay (+) -->White/Red wire 12v (+) at ignition harness 5 Violet Starter Output (+) --> Black/White wire (+) at ignition harness 6 Accessory Output (+) --> Blue/Red (+) at ignition harness 7 12v Constant input for ignition 2 and flex relay (+) ---> White/Red wire 12v (+) at ignition harness 8 Pink Ignition 1 input/output (+) --> Black/Red wire (+) at ignition harness.
Oct 20, 2014 | Viper Security and Remote Start System...
See all Viper Security and Remote Start System (basic Questions
Viper Security and Remote Start System (basic install included) Logo
166 people viewed this question
Top Viper Home Security Experts
Will Halftowaite
jason
Kevin Daniels
Are you a Viper Home Security Expert? Answer questions, earn points and help others
