Question about Kodak EasyShare C533 Digital Camera
Put new batteries in camera, turned power on but the camera lens doesn't open. Only the green light flashes a couple times then starts blinking red then shuts off. nothing displays on the screen
You must use the right batteries
Posted on Jan 10, 2009
    Sergeant:
  • 431 Answers
Make sure the battery are properly charged
Posted on Jan 08, 2009
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
Dp 1 doesn´t function when the SD-card was returned to the camera
Try this...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
May 27, 2010 | Sigma DP1 Digital Camera
Turn on power, green light flashes, powers off
Hi there its happens when the lens not ready for work. Some how its not able to stable his focus method. That's why its come out & go back. There is a chances of lens guide pin disturbed or damaged & thats why green light blinking continues. Its mean he inform you there is a system error. So please visit the service center for repair that. Thanks.
Apr 02, 2010 | Rokinon DZ1000 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
I dropped my camera and it won't turn on!
OoW repair: 48,44 pounds
Alternative Trade up: Where you trade your old camera to a new camera for 25-30% less than market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Camera will not open most of the time,the lens
Your problem may be due to a buildup of corrosion on the battery contacts inside the camera preventing full battery power from flowing into the camera. Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during the cleaning, then wipe both ends of the batteries and reinsert them into the camera. It's not a cure-all. but this cleaning cures the problem about 90% of the time. I hope it works for you.
Sep 03, 2009 | Olympus SP-310 Digital Camera
Problems with camera
Hi everyone,
I found you because 10 minutes ago, my camera exhibited the same behavior as all yours. All of a sudden, the red and green lights started blinking on and off and nothing worked. I just tried switching batteries and the camera is working! I am using a couple of RCR-V3 Li-ion rechargeable batteries, which I purchased on Ebay three months ago. Thought I'd pass it on.
Take care,
Rosane.
Jul 17, 2008 | Olympus SP-350 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Dead
try taking your memory card out and then replacing the battery to see if you can get it to power on and get your lens to go back in. If that doesn't work you will probably have to send it in for repair.
Sep 11, 2006 | Casio Exilim EX-Z50 RED STAR Digital...
Kodak EasyShare C533 Digital Camera Logo
309 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
