Question about LG LHT734 System
How to hook up a blu ray player to a t.v. without HDMI slot
I have a Hitachi 65S500 t.v. and just upgraded to a directv HD-DVR when the technician went to hook up the receiver to my t.v. he said that my t.v. did not have a HDMI hook up on it so he hooked up the receiver useing component cables my question is how do I hook up a sony blu ray machine without a HDMI cable I already have the component cables hooked to my t.v. for the HD-DVR can I use more component cables or do they have to be hook to the same inputs that the DVR is hooked to in that case am I out of luck and can't hook up a blu ray I checked my manuals and see that my t.v. does have a DVI-HDTV hook up can this be used instead
  • Anonymous Dec 31, 2008
    same problem play station 3. 65 inch hitachi.
Cerfer39
  • 709 Answers
SOURCE: DVI Input Shot
Hi Alanx,
In most cases like yours, the connector has a bad solder joint inside the TV. This occurs from strain from where the HDMI cable gets bumped or bent against a wall or something drops on it. If your skilled and brave, you can go into the TV and check the DVI conector and how well it is soldered in place. Repair the solder joint if this is the case. Good luck. Just think of how proud you will be to have repaired this yourself.
Posted on Nov 24, 2007
SOURCE: PS3, playing blu-rays
I have a mate with this problem also . He rang Tv company and was told that model TV doesn't support blue ray so will not play .
Posted on Aug 26, 2008
  • 19 Answers
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Posted on Feb 21, 2009
omaharox
  • 166 Answers
SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Posted on Jan 18, 2010
  • 50 Answers
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Posted on Apr 27, 2010
How do I start watching Netflix on my hitachi smart TV
Open the Netflix app and sign in to your account!
Dec 24, 2016 | Netflix
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
I am unable to get audio after hooking up to HD DVR
If using HDMI you may need to run the Audio from the Red & White AV, Audio RCA's some HDMI don't send the audio over the HDMI.
Feb 10, 2010 | Televison & Video
No picture from Blu-ray
If the TV works fine with other sources the problem is the HDMI output is not enabled on the BD player.
Most BD players do not output both HDMI and composite formats simultaneously. Check to make sure the HDMI output is selected on the BD player and the TV. This information is in the manuals, read the book.
Cheers
Jan 15, 2010 | Hitachi 57F59 57" HDTV
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Remote Control Not Communicating with TX-DS787
Hello, I am sorry about your issue. Your hook up should have nothing to do with the remote. You should get some functions like on/off, volume control. Thank you, Onkyo, USA
Apr 25, 2017 | Onkyo TX-DS787 Receiver
Open Questions:
LG LHT734 System Logo
562 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
Mike Duncan
Mike Duncan
pankaj rautela
pankaj rautela
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
