Question about Mitsubishi WS-65813 65" Rear Projection HDTV
Mitsubishi WS-65813 Guys, this thing does nothing when I hit the power button. A neighbor who is vaguely familiar with TVs said he thought it was a control module. Is it time to get a new TV or . . . what do you think? Thank you. Mitch
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Someone first needs to check the module inside to see if their has been fluid leaking at least get it looked at this is a great tv designed to last alot longer then the new ones
Posted on May 05, 2010
No four wheel drive
problem could be transfercase shift control module.or check 10 AMP fuse to the front axle switch since the transfercase module will send a signal to engage front axle then transfercase encoder is mounted to the shift motor so the transfercase control module control shift control motors also transfercase speed sensors.the transfercase assembly complex system work on since every thing electronic controlled.
Nov 28, 2013 | Cars & Trucks
Dish remote 2 changes channels on both tvs and dish remote 1 changes channels on both tvs
Is the receiver in dual mode? Go to the receiver, open the door, and hit the mode key. If both TVs are still showing the same thing, then the issue is not the mode.
Go to TV 2 (the one without the receiver) and make sure the TV is tuned to channel 60 or 73. If it is still showing the same thing, go to TV1 (the one with the receiver) and hit Menu, system setup, Installation, modulation (menu 6-1-5). make sure the modulation for tv2 matches which channel you put your tv2 on.
Still showing the same thing? check the back of the receiver, the RCA cables (red/white/yellow) are plugged into the TV1 ports not the TV2 ports.
Showing different things but the remote still changes channels on both tvs? Go to TV1, hit menu twice, near the bottom there are two boxes each with a number. This is the address for each remote (tv1 and tv2). On the TV2 remote hold sat until it stays lit, choose a number different than on the screen, touch pound (#), the sat light blinks three times, hit record, the number on the screen should change to match the one you typed in.
Still being silly? Call a priest, you have a poltergeist!
Oct 24, 2013 | DISH Network IR Remote Control
Wireless XBox controller won't sync with the PC adapter
I finally found a solution that works for me (most of the time). I bought a USB hub (un-powered at the moment) and the problem seems to have disappeared. The Hub however isn't the solution. Running the controller or the hub from the rear motherboard ports is.
I was initially using the 360 wireless receiver from the front ports on the PC which are driven by a different circuit on the motherboard than those from the rear of the PC.
When the receiver is run from the rear ports or in my case a hub powered from the rear ports it works most of the time.
Ocassionally the receiver doesn't link with the 360 controller however unlike last time when pressing all kind of combinations of re-sync buttons did nothing, all I do now is press the very tiny white button on the front of the controller and it links up like it should within 1.5 seconds.
I hope this helps guys as the controller is great when working.
Cheers
Karl
Dec 25, 2008 | Microsoft Xbox 360 Controller
Xbox turns on but i have no green lights
What appears to be the problem in my case is that the RF module board in which the power button and the controller sync lies has been damaged. If aboslutely no lights come on when you power on your xbox 360, but it loads like normal, something has fried on the module and needs to be replaced. You can ether contact microsoft about this, or buy one off of ebay and install it yourself or have someone who knows how install it for you. Doing so would void your warrenty of course though.
Dec 10, 2008 | Microsoft Xbox 360 Console
Acer Aspire 5600 wont turn on.
Ther is only one thing that you have not tried I think. Try to remove the CMOS battery from the motherboard for about 15 minutes and reconnect it. It's a small lithium battery.
Nov 25, 2008 | E-Machines T1360 PC Desktop
Fuse ,zener diodes keep blowing.....
hey eriez
if your familiar with repairing tvs, this aint that hard. just locate the blown fuse and the zener diode. and look for scalded and burnt component parts as well....
unfortunately, there is no free service manual found on the net today for your JVC CA-V808t... however, there are lots of sites that sell them though..
any thoughts that you want ... just post it here...
Apr 08, 2008 | Audio Players & Recorders
Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
Jan 26, 2008 | Frigidaire FSC23F7D Side by Side...
My control panel for the oven does not work(press buttons w/ no response
If the LED display is blank, then you have a power problem. first make sure there is power to the appliance. If you can determine this, then check the transformer on the control module. All these things require some familiarity with electronics and electricity. Depending on you is how to handle this.
Nov 30, 2007 | Whirlpool GY396 Electric Kitchen Range
Mitsubishi WS-65813 65" Rear Projection HDTV Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
