Question about Honeywell HE440A1005 Humidifier
Honeywell HE440A Humidifier filters changed, now won't turn on
Now that I have changed both the chlorine and RO filters, the humidifier will not turn on. There is a clicking sound, like a relay is trying to turn the humidifier on, but nothing happens. What now?
Thanks
  • Stephen Evans May 11, 2010
    Can you tell if the buzzing is coming from a motor or soleniod?
SOURCE: Honeywell HE440A steam power humidifier
Honeywell has had lots of problems with this humidifier. They are coming out with a completely redesigned steam humidifier that will be available in a month or two. If you know who installed it (through equipment stickers and such) you can probably get them to swap your old trouble prone unit for the new design for just the labor. If they won't, then push them to talk with their Honeywell distributor about it.
The problem is most likely a stuck float in the humidifier. There are two floats that run up and down. One that tells it when to add water, and one that is a safety. They both tend to get stuck with mineral deposits.
You can fix it by unplugging the humidifier, turning off the water, draining the pan (unscrew the drain on the bottom a few turns), disconnecting the water lines and wires (2 molded plugs and 2 screw terminals-don't worry about if they get swapped). There should be a couple of screws that lock it into the ductwork such that when you remove the screws you can pull the whole unit out to see inside the water tank. Then just clean everything out well and put it back together in the same order.
You really do want Honeywell to get you a new humidifier though.
Posted on Nov 17, 2007
SOURCE: Honeywell Humidifier HUT102m
its the worst design to fill it up that you could imagine. i was lost for a 1/2 hr trying to figure it out. well that 'easy to fill' feature on it means that you have to flip it upside down, balance it on its awkward shaped top, press in that spring loaded piece on the underside with one hand, and fill it (takes forever) with your other free hand in the same spot (apparently it opens up a valve that allows water in).
Posted on Jan 21, 2008
JohnSc
  • 21 Answers
SOURCE: Honeywell HCM-525 owners/operation manual NEEDED PLEASE!
The filter should be located below the tank. the tank should lift off of the unit and there should be a rectangular cavity where the filter fits. You will most likely find the old filter dried up and filled with a white crust. That is salt and other minerals in the tap water that the filter catches.
Posted on Feb 11, 2008
SOURCE: Honeywell True Steam Humidifier
Hire a certified heating specilist and pay for the installation. When you do, you are not only paying for the installation but you are paying for the many years of knowledge that goes into his or her carrer,
Posted on Nov 08, 2008
SOURCE: Continous ware flow on Honeywell HE220A Humidifier
I am having the same problem. I have had my humidifier for about 5 years now and I just started having the problem where the water continuously flows through the solenoid. I took apart the solenoid by removing the fittings from both sides. When I did that, I noticed that there was a hole in the metal that allowed me to see through to the other side. Apparently, it had corroded and and broken through, allowing the water to pass through the solenoid without really going through the valve within the solenoid. There are several sites that sell replacements for about $70, which is not cheap, but cheaper than buing a new humidifier for $120. Here is one site I found: http://www.iaqsource.com/product.php/honeywell/32001639-002/?product=112783&category=1142
Posted on Nov 20, 2008
White dust in the house
Use mini RO system or good filter to feed humidifier with water that contains less minerals.
Jan 24, 2013 | Honeywell HE360A1027 Whole House...
HE440A Steam Power Humidifier
The most common cause of overflow is when hard water deposits build up and prevent the float from closing. You'll have to open up the unit, make sure there's no water in it, and clean out any mineral deposits.
The problem with these steam producing units is that there is no built in way to remove those deposits automatically. The water comes in, evaporates, and leaves anything else that was suspended in it behind.
Nov 14, 2007 | Honeywell HE440A1005 Humidifier
Two furnaces one humidistat help on wiring
Honeywell tech support is awesome here in Minneapolis, I think you need seperate humidistats but check with HW, number is in owners manual.
Nov 21, 2009 | Honeywell Power Humidifier: Furnace...
Cleaning a furnace humidifier steel filter?
Most water panels are generally replaced once a year on flow through humidifiers.
Dec 20, 2008 | Honeywell Power Humidifier: Furnace...
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
Water is constantly filling
Have you checked the position and function of the floats in the pan?
Nov 20, 2007 | Honeywell HE440A1005 Humidifier
Humidifier Gives Off an Odor
Odors are common because water stagnates in the tank. 1) Unplug the unit. 2) Empty the reservoir, mop up any damp areas, and clean the tank and evaporator belt with a mixture of one gallon water. Add 2 tablespoons of chlorine bleach to the water for stubborn smells.
Jan 18, 2006 | Honeywell HCM530 Humidifier
Honeywell HE440A1005 Humidifier Logo
114 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
