When not in use and when it has not been in use the microwave emits a single beep. When I attempt to set cooking time it will not set. Again it emits a single beep. If I flip the breaker and then turn it on again the microwave then functions properly. Any suggestions?
It sounds like you have a bad computer board,when you shut down the power and turn it back on you're resetting the computer and it will work and then fail after a while.the parts are big money for this unit,200 dollars and up,you can get a basic microwave new for like 250,the micro computer is almost 500 dollars
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Wall-oven-Parts/Model-KBHC109JSS05/0593/0125400/W0608053/00002?blt=06&prst=0&shdMod=KBHC109JSS05
go here and you can look up the parts,i use my machine just to reheat food,like i say you can get a new machine for around 250.good luck and hope this helps
Thanks...not what I wanted to hear but I'm not surprised!
margaret,have you tried leaving it unplugged for a day,i have a microwave almost with the same problem,it's digital and the clock and board with all the numbers from 1 to 0 would disappear,if i unplugged it it would reset,i left it unplugged for a day and it's been ok now for over a year.
SOURCE: Kitchenaid Superba Model #ksrb25fkss01 Serial # sm0426177
what about the freezer?. Check door seals with a dollar bill, close the door with the bill in different spots, if bill comes out to easy then seals might be bad or a door adjustment is in order. Make sure the coils underneath or behind do not have a layer of dirt on them. Try these simple steps and let us know thanks
SOURCE: kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
SOURCE: over tempature reset keeps beeping
its registering a warm temp, you reset it but when it checks again in 2 hours or so its still seeing a warm temp whichi s why the alrm is going off, id look at the contents of the refrig for signs of defrosting, icecream not hard enough, ice maker not producing and melting, moilk spoiling premature, butter too soft.
SOURCE: Beeping or Chirping
probalby not relates, but the beeping is ususally accompanied by an indicator light as to why its blinking, perhaps the door open alarm???
SOURCE: kitchenaid side by side too cold. Freezes everything.
the damper motor on the refrigerator portion is not working properly
