I have a laptop hard drive I want to retrieve information off of..
  • DService May 11, 2010
    Is it SATA or IDE?
    The end of a SATA drive looks like this
    The end of an IDE drive looks like this
  • 60 Answers
If you are talking about deleted files then google.retrieve lost data or something along those lines.
or even use www.download.com and look for it there. becareful as most of them will ask for funds after download but there are free one's out there just keep looking..
if this is not what you mean by retrieve data then pls clarify further as to what you need :)
Posted on Dec 23, 2008
Disk read error preventing startup?
Your hard drive might be damaged. Each time you attempt power it on you risk further damage. If you have valuable information on it you should contact a shop who specializes in data recovery.
May 22, 2014 | Dell Inspiron 1501 Notebook
My Sony HD-E1 1TB hard drive is not being recognized by my laptop. The light flashes on the drive and it makes a ticking sound. how can I recover the information stored thereon?
If it is doing the tick of death then it is not likely you will be able to retrieve anything unless you have it sent to professionals for retrieval. It can be expensive too.
Feb 13, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
My Laptop does not recognize the Maxtor 3200. My laptop comes up with : unknown device notice
If it's doing the same thing on 2 different pc and the operating system on both of those pc is Windows XP or Newer then the drive is dead.
Sep 02, 2012 | Maxtor Personal Storage 3200 (U01E200) 200...
How do you retrieve raw files from external hard drive? What format are they in? Will they be the same quality?
Files are Files are Files. The .raw file type is just a specific method of saving data with a lot of information. The .jpg's are a much more compressed version that really save a lot of space, whether it be on a hard drive or memory card.
You should be able to use your external drives much like a memory card or internal hard drive. You should be able to move files from one drive to another, deleting or copying files wherever you feel necessary. There will be no loss of quality if you move a file from point A to point B.
Jul 03, 2012 | Adobe Computers & Internet
Damage hard drive
If you've damaged your laptop's hard drive, there isn't too much you can do about the issue depending on the amount of damage. If it is only crashing, but still operable, you may just have enough time to save some of your information with an external hard drive or other form of data storage. Retrieve your preferred data storage device (an external hard drive would be the best choice in this situation) and try to save as much data from the broken hard drive by copying your data over to a backup folder on your external hard drive. You can find your external hard drive under "My Computer" once it has been plugged in. After you've saved your data, I would suggest buying a new hard drive for your laptop and replacing it carefully. Most laptops can be opened up from the bottom (DON'T undo any screws) and have their hard drives removed, so that you may be able to place in a new one. Be sure that you buy a compatible laptop hard drive, and not a larger hard drive meant for desktop computers.
May 06, 2011 | Computers & Internet
Error code0146-2000
Doing a little digging, it looks as though this is a hard drive failure code for some Dells including the Inspiron 6400. You will probably need to replace the hard drive. IF you need to get information off of the existing hard drive, I would try putting it an external enclosure. You may be able to retrieve some of the documents from there.
Jan 07, 2010 | Dell Inspiron 6400 Notebook
What do I do if my laptop is freezing up?
how old is it? check the power supply isn't faulty of the laptop. Poor or bad connections can cause this.
Also, check the hard drive isn't duff, best trick (sounds silly but works).
Locate the hard disk on the laptop (on the underside) power it up and listen to the spinning effect by getting a philips screwdriver locating on the screw of the hard drive cover, power up and listen using the handle end for the spinning. If it sounds as if it's slowing up and down or "rough" in anyway then the hard drive is worn.
A worn hard drive will inevitably cause intermittent data retrieval by throwing gargled information into the system buffers within the hard drive memory.
If hard drive is ok, check you haven't downloaded a virus. It's best to wipe of all information and start again. Please make sure you back-up your important information whilst it still works with a usb stick or dvd back-up etc Good luck!
ps: make sure the memory hasn't been updated with the wrong type of density too. or unclip the memory and relocate it again
Dec 20, 2009 | Toshiba Satellite A100-S8111TD Notebook
Removal of hard drive
See:
http://www.acerpanam.com/synapse/data/7117/documents/TM_5720_5710_5320_5310_Columbia_Dallen_OLM_Eng.pdf
search for the "base view" picture, to see which screws hold the cover over the hard-drive bay.
Apr 27, 2009 | Acer TravelMate 5720-6462 Notebook
Hard drive failure on IBM T43
I have a ThinkPad T43,
Now it's hard drive is broken so when i change the new hard drive Hitachi 160GB it display the message as below.
Could you help me to terminate this error message.
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
I try to update firmware of the harddrive but still appear the message the same.
Apr 23, 2008 | IBM ThinkPad T43 Notebook
Open Questions:
Computers & Internet Logo
63 people viewed this question
Alun Cox
David Payne
David Payne
