Question about Zenith Z20A06D/X TV
Can't read the news ticker on the bottom of the screen
I have a Zenith Z20A06D. The problem I am having is I can't read the news ticker on the bottom of the screen (like on CNN for example). I can olnly see the very top of the ticker and it's letters. I can't tell of the picture is projecting bigger than the screen or if the picture is projecting too low. Of course, there are no longer any adjustments on the back of the TV. I had a TV repairmen come to my house for a problem with a differnt TV and he pushed the buttons on the front of the TV (Volume, Channel, Menu, etc.) in a certain combonation to get to a sort of hidden menu where he could make adjustments to the picture. I can't figure out how to do it. I don't even know if it will help me. Any suggestions? Thanks
2 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: TV Screen Does not Display Entire Image
Most likely it has a horizontal width control on the inside of the set on the main module. It is usually to the right side of the set near the high voltage transformer. I advise caution unless you understand the operation of the tv and the components near the control.
Posted on Jan 30, 2007
ZENITH TV OUT OF FOCUS
hi,
You tv have problem with the picture tube base socket. After a long year of use the contacts of the base socket will become dirty. You have to replace the base socket. You can find the base socket on the PCB which place on the picture tube neck
Remove the base socket and buy a new on with the same size and fix the new one. This will solve the of out of focus problem.
Have added the picture of base socket how its look like.
Ajin
Feb 09, 2012 | Zenith Z27X76R 27" TV
Ticker along bottom of screen for news channels and sports channels is being cutoff along the bottom. That is, the ticker moves right to left and I can read it but the bottom 10-15% of the letters is...
I might need a little more detail to solve this problem - I suspect the problem is an incorrect setting on your cable/satellite receiver (assuming you are using one), but let's start with the TV.
Firstly, switch the TV on and select a channel where you can see the ticker. Then press the "FORMAT" button (above the red REC/CONNECT button) on your Mitsubishi remote control. This will change the screen aspect ratio and the current setting will be displayed on screen. Each time you press the FORMAT button the screen size should change.
The screen aspect ratio settings for your TV are STANDARD, EXPAND, ZOOM, STRETCHED and NARROW. Press the FORMAT button repeatedly until "STANDARD" is displayed on the screen. If the ticker is still cut off, you need to change the aspect ratio setting on your cable/satellite receiver.
Please note: If the TV will only allow you to select STANDARD, this is not a fault. It simply means that the aspect ratio cannot be changed on the TV because it's displaying a picture from an external source, i.e. a cable/satellite receiver.
You should then look for a button on the front of your cable/satellite receiver or the cable/satellite remote control marked "FORMAT" or "ZOOM". When you have located this button, try pressing it repeatedly until the ticker is both fully on the TV screen and the picture covers the entire screen.
If you don't have a FORMAT or ZOOM button for your cable/satellite receiver or you are unable to set the picture size correctly, leave the TV set to STANDARD and then reply to me with the brand and model number of your cable/satellite receiver. I will then be able to assist you with finding the correct picture settings and give instructions on how to set these correctly.
I hope this helps - please post back here if you need further assistance.
Regards,
BElectric
Jan 15, 2011 | Mitsubishi WS-73909 73" Rear Projection...
My Zenith C32V28 television does not display the top and bottom of the picture. I phoned Zenith tech support who told me that it was the satellite signal. I called the satellite provider who advised me it...
This is applicable to Bell Television Services (Canada)
I solved the problem myself after two calls to both Zenith and Bell Television satellite service. On the bottom left of the Bell remote control there is a * (STAR BUTTON). Press this * button and within two seconds you must press the channel change button up or down. This will do two things. One; it changes the channel; and also changes the ratio of the satellite signal. There are three satellite signal ratio settings. Try this when you are tuned to a TV channel such as BNN (Canada) (Business News) or The American channel which has a stock ticker usually displayed along the bottom of the TV screen. Select the ratio (setting) that allows the stock ticker to be displayed......hope this helps.........Jim McP
Nov 10, 2009 | Zenith C32V28 32" TV
Bottom of screen gets cut off.
you need to press the aspect ratio button to change the view is should bring up the news ticker into view if you have your view set to smart try pressing up on the d-pad in the middle of the remote
Aug 06, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Image is too large for screen
**** man, i have the same problem, sucks in video games where the objective is shown at the top of the screen and i can only see the bottom half of the text.
May 22, 2008 | Apex Digital AT2702 27" TV
Sony bravia kdl-40v3000 blurry news ticker
without going to hd, contrast to full, color, tint and brightness to middle, then adjust sharpness for optimum clarity
Mar 17, 2008 | Sony BRAVIA KDL-40V3000 Television
Over projection on apex hd 51"
try to go to menu using ur remote and adjust the v-size/vertical size....
Jan 29, 2008 | Apex Digital GB51HD09 51" Rear Projection...
Jan 29, 2007 | Zenith A32B86R 32" TV
News ticker off bottom of screen, how to adjust?
sounds like its stretched out just a bit. Do you feel comfortable with messing around inside where theres 100s of volts??? if you do then in the vert curcuit theres a small control called the vert height control right on the printed curcuit board. adjust it slightly so you can see that full pic but not the black partm of the pic. I WOULD HIGHLY RECOMEND thaT if you have no experience with this then leave it to a pro as afterv all they will charge you a minumum beanch charge to adjust the set for you Im sure as it is a minor thing to do. good Luck
May 02, 2006 | JVC AV-30W475 30" TV
Televison & Video Logo
160 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
