Question about Kenmore Kitchen Ranges
Kenmore Oven gives fault code F3 when you turn on oven
I checked online & found F code is temp sensor with open circuit. I replaced the sensor & still get the F3 code. Any suggestions?
Kenmore Model# 278.4558814
    Scholar:
  • 127 Answers
Check the sensor harness, and the sensor harness connections at the sensor and oven control for an open circuit. Check for resistance on the sensor. It should not read as an open circuit. If the sensor shows resistance and the wiring and connections show continuity, then the problem is most likely on the control board itself. Possibly a bad connector or crack. You will probably have to replace the controller board (clock).
Posted on Dec 23, 2008
I have a kenmore ultra bake, model #665 75022101 and the oven doesnt work the code E0-F3 comes up. i have the manual and have tried what they said to do but it doesnt work. i have bought a new sensor
The error code message F3 E0 indicates an open oven sensor circuit. This is the component that regulates the oven temperature.
First disconnect electrical power to the range. Pull the range out & remove the rear panel to the control area. Unplug the 2 violet wires on P3 5-6. You will need to have a meter for testing, set the meter to read ohms (resistance). Place the leads from the multimeter across the 2 violet wires, the meter should read 1080ohms if the sensor is good. If you do not get the correct reading you will need to replace the oven temp sensor.
The oven temp sensor is mounted to the inside of the oven cavity. You will need to remove the lower section of the rear panel to access the sensor connector. Unplug the sensor & slide it back into the oven cavity to remove & replace.
Taken from...
http://www.managemylife.com/mmh/questions/120802-kenmore-range-displaying-e0-f3-error-code
Jan 12, 2012 | Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
F1 error code on the ERC. No replacement ERC from Sears (Kenmore) or GE (manufacturer). The oven temp sensor is within specs at 1100 ohms @ RT.
The F1 error code refers to one of the buttons on the touch pad being the problem and not spefically the erc unless on your model the touch pad is built in to the erc.On older model the touch pad was a different part on newer models its only part of the erc
Yes indeed 1100 ohms is the exact spec.for the sensor at room temp. however if the sensor were bad the error code would F3 if had a open circuit(infinate ohms) and F4 if it were shorted(zero ohms)
Jul 29, 2011 | Ovens
F3 error (sensor replaced) kenmore stove Oven reaches proper temp then about 15 minutes after starting beeper goes off and error code f3 appears
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then check the wire harness connecting the control & sensor (as you have already replaced the sensor) however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 05, 2010 | Kenmore Kitchen Ranges
F3 code
F3 E0 5 Top oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E1 6 Top oven shorted Check for shorted sensor circuit, otherwise replace sensor F3 E2 9 Bake range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E3 8 Clean range over temperature At room temperature, sensor resistance should be 1K to 1.1K. If not, replace the sensor. If the sensor checks okay, replace the control. F3 E4 10 Bottom oven sensor open Check for open circuit. Sensor resistance should be 1K to 1.1K @ room temperature. If not, replace the sensor. F3 E5 15 Bottom oven sensor shorted Check for shorted sensor circuit, otherwise replace senso
Feb 24, 2010 | Whirlpool GS460 Gas Kitchen Range
Ge true temp oven with an F1 code...what is it...model #J KP15AOA
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2010 | Kitchen Ranges
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 and F2 Error Codes
If hitting clear/cancel won't clear it try unplugging and then plug it back in. My guess is the oven control is bad. Here are the fault codes for this model.
Failure
Code
Condition Check/Repair F0 or F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad F2 Oven over temp - exceeded 590F with door in unlocked position or 990F with door locked If actual temp condition occurred, look for welded relay contacts or high resistance connection or any cause in the oven temperature sensor circuit F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact F4 Shorted oven temperature sensor circuit Same as above; check for melted connector or both leads shorted to ground F8 Component failure within Electronic Range Control (ERC) effecting temp processing circuits Replace Electronic Range Control (ERC) F9 Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch Check wiring and test operation of switch
Jul 15, 2008 | Ovens
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kitchen Ranges Logo
143 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
