Question about Baumatic 23 in. BDW10 Built-in Dishwasher
Error E1 comes up on dishwasher
Baumatic BDW -10 built in
  • 1 more comment
  • steve520 Dec 26, 2008
    Tried the suggestion without success.
    Thank you for the assistance. The solution didn't work and was unsure what to rate the solution.
  • Anonymous Mar 30, 2014
    is it a blocked filter or jet
    President:
  • 373 Answers
E1 error comes up when faucet is not opened. this is shown up when it takes longer filling time.
The solution for this is to ensure that the inlet hose is not kinked or crushed.
Posted on Dec 23, 2008
  • 1 more comment
  • Suresh Thrithandam Venkata Lakshmi Narayana
    that does not mean its inappropriate. you can atleast rate me as "thanks for trying". please change the rating. that is the result i found online.
    just in any further doubts check this link of the baumatic manual.
    error E1 on page 24
    please do check and change the rating because i could only answer based on the question. and please be more specific next time.
    thank you.happy holidays.
    well then please change the rating if possible to atleast "thanks for trying", because it affects me a lot.thank you in advance.
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Nov 15, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Our BDW 13 keeps tripping our fuse board
your cicuit is overloaded. hook the DW up to its own cicuit, or at least one that will not overload it. Circuits should not be loaded to more than 80% of their capacity. 15 Amp load no more than 12 amp.
when motors/pumps start they use the most load or power, or when your DW turns on the heat.
Nov 01, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Need door locks for bdw 10 and bdwa where can i get these
You will have to look in ypur local yellow pages or phone directory, and try to find a appliance parts warehouse. They will have or can order what you need.
Oct 02, 2009 | Baumatic 23 in. BDW10 Built-in Dishwasher
Looking for reset switch
If your getting `E3` then it cannot be reset, one of the two thermostats on the heater element cannot be reset and has to be replaced, around £18, you can test which one of the thermostats is faulty by using an `ohms` tester, open circuit, faulty, this is a very common problem with these.
Sep 08, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic bdw45.1 integrated dishwasher
sorry i have no knowledge of this "baumatic" product line. please repost with another expert
Jan 28, 2009 | Baumatic 18 in. BHD45 Slim-Line Built-in...
E4 shows up when i turn on my dishwasher
E4 is an overfill code caused by water pressure problem.
On the base of the unit - (underneath the kitchen plinth) there are 2 black plastic clip panels - each these of with a blunt knife or screw driver and turn off the appliance at the mains. In there you will see lots of wiring etc. Simply get a dish cloth and mop up any water that is in there, particularly at the back left as that is where the sensor that detects the over flow is. Its simply a rubber valve that is boyent and so lifts when water is present. then once most of the water is removed, turn on.The problem would be solved.
TO PREVENT THIS HAPPENING - when you take off the kitchen plinth you will see 2 small clear pipes in the centre - between the 2 plastic panels. These are cable tied. Simple cut the cable tie and feed the pipes out of the dishwasher - place a bowl under tehre if you whish. This will prevent overfloww water enterin the base. BE WARNED BY DOING THIS THE DISHWASHER WILL NOT HAVE ANY OVERFLOW PROTECTION CAUSING POSSIBLE DAMAGE TO KITCHEN AND APPLIANCE. My advice would be to leave it in place but try to prevent overflow - i.e rinse plates first or try a different brand of wash tablets. If it does happen then the fix is simple and you definately do not have to remove the unit as many people imply.
Jan 20, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Baumatic 23 in. BDW10 Built-in Dishwasher Logo
1,145 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
rich2481
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
