1994 Oldsmobile Cutlass Ciera Logo
Posted on Sep 01, 2012
Is there a deck I could put in a 1994 Oldsmobile Cutlass Ciera for use of subs?
I just bought a Cutlass Ciera. Perfect shape, but I have a pair of subs I would like to put in the trunk. People are saying I will need a new deck in order for the wiring because the original is not compatible. Is there a deck or something I could use to get it available for sub hook up?
brian murray
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Sep 03, 2012
brian murray
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
2196
Points
32
I have a kenwood cd player i installed in mines with amp and 15 inch sub woofers in mines
2 Related Answers
Anonymous
  • 564 Answers
  • Posted on Nov 22, 2009
SOURCE: 1994 oldsmobile cutlass supreme sl the fuse box for signal lights
the fuse box will be in 1 of 3 places (1)glovebox (2)under dash by drivers foot kick panel or (3) under hood .
Anonymous
  • 3 Answers
  • Posted on Dec 06, 2009
SOURCE: 1995 oldsmobile cutlass ciera wiring diagram
they can be bought on line but the easiest way is to buy a manual from local parts store, or possibly check one out of the local library
1994 Oldsmobile Cutlass Ciera. No power to window controls on driver's door panel.
Question edited for fix all the spelling errors.
Question moved to model category.
On a car that age, either the switch is faulty or the wire has work hardened and broken in the wiring harness from the door edge to the door frame.
https://www.google.com/search?q=1994+Oldsmobile+Cutlass+Ciera.+No+power+to+window+controls+on+driver%27s+door+panel
2helpful
2answers
1994 Oldsmobile Cutlass Ciera. How do you replace the headlight dimmer switch please?
It is mounted to the base of the steering column. there are two small screws that secure both the switch and the ignition switch. Just remove the necessary screws and the old switch being careful to not let the rod fall out of the steering column- tape the rod in place. put in the new switch and replace the screws. here is a diagram of your column:
https://drive.google.com/file/d/1ah2LozuwGzsTCQoOYJbqO-q1GDPOzmYE/view?usp=sharing
No heat on my 1994 oldsmobile ciera s 3.1 liter engine
have already put 2 thermostat on it but no heat the heater core if bad they say would make your floor be wet, mind is not. when the thermostat was put in they turned 2 screws on the top after that no heat
Warped cylinder head on 1994 Olds Cutlass Ciera... Options?
With heads that have a cam in them resurfacing is a non-option. If you resurface the head it's still bent and the cam(s) are binding in their bearings.
You can have a head pressed back into shape, it probably costs more money than going to the junkyard and getting a used head but may be comparable to a new head.
When you put another head on it don't grind or lap the valves. Grinding the valves on a motor that's not had a ring job tends to wash the rings out.
lp
Does it have FWD
as written by you, yes
a cutlass surpreme is rear wheel drive thay year
Ignition lock 1994 cutlass ciera
You need a new ignition lock cylinder. One of the tumblers inside probably broke.
2helpful
1994 old cutlass ciera 3100 blown head gasket.
Get a Chilton's book on the car. It will take you thru the whole job, and give you the torque specs for putting it back together. You will need a torque wrench, foot pounds, and a good socket set.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
