Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
OUr Sony Grand Wega KDF-60XS955 has a blue corner
And very small blue dots all over the screen. We replaced the bulb and that did not fix the problem
  • 4 more comments
  • thepacks Dec 31, 2008
    hundreds of little blue dots and few blue splotches on the screen
  • ubrokifix Jan 08, 2009
    yes
  • Anonymous Jan 11, 2009
    Same here blue in the corner.
  • debi_frank Feb 08, 2009
    Bright blue glow left lower corner that extends across the bottom of the screen. Replaced the lamp to no avail. TV is 4 years old... what now??
  • Anonymous Feb 20, 2009
    same blue ghost screen. 100's of bright blue dots. Here's something new, now theres "black branches" that came down from the top. what up?
  • flemingmaryj Feb 21, 2009
    blue dots all over screen
    Problem Solver:
  • 5 Answers
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the $1300. (not incl labor), Optic Block that was replaced to fix the problem. That part contains all new LCDs, & Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended)
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have FACTORY extended warranties because of some known problems with the blue LCD panels.
The tech checked my Service Codes & showed me the TV had been running for 10051 hours in about 4 years - on the Original bulb! He was quite surprised because he said the bulbs usually last about 5000 - 7000 hours. He also said it's good to replace them BEFORE they go bad, because they can sometimes burn out the amplifier that powers the bulb, (which is a seperate piece that attaches to the outside of the Optic Block). My TV is like new now.
Posted on Jan 17, 2009
    Problem Solver:
  • 13 Answers
If it is blue in a corner , then the blue light filter is probably partially melted.
Posted on Dec 23, 2008
I have the Sony KDF-60XS955. It has a blue corner about 3 inches on the lower left-hand corner which is on all the time. Also, when there is a black screen, you can see small blue dots all over the...
momkennedy13,
You have the fatal Sony KDF optical engine issue. Sony has had most if not all these models fail prematurely. The solution is to replace the optical engine. The problem is they are not available as a new unit only a repaired unit so the problem will no doubt reappear in the future. Many people have had success with contacting the Sony customer service representatives and can usually get them to sell you a new unit for a couple hundred dollars. For my money that would be the best way for you to go. I have a tip at http://www.fixya.com/support/r7851924-sony_projector_yellow_or_blue_dots which explains the problem and offers solutions.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots on screen. Blue band on on/off side of screen.
blue dots on screen,bright blue haze right corner to north westpast center of screen.
May 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue area on my screen
Your blue LCD panel is failing. It is within the Optical Block and the entire block must be replaced in order to repair this. Over time (usually a short amount of time) this problem while progress until the picture is bad enough that you will want it fix immediately. So, it's good that you are looking into this now :) Here is a PN for the Optical Block... PN: A-1084-668-A I hope this helps.
Mar 17, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots, marks, and a bluesh tint on the screen.
sound like you have a bad optical block which is a common problem for sony lcd projection sets
Jan 04, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Large blue covering entire bottom right corner and blue dots
optical block failure call sony, they are a known fault on all rear pro sets from 2003-2007, they may replace for free, have extended warranty on this part.... there are lawsuits pending against sony over this problem
Sep 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tiny Blue Dots all over scree. Now wont turn on.
is munes the same way, if it is try to clean
back mirror. if that don,t you need to call sony.
because it your eng is bad wicth is whear the pix come from.
Aug 25, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
KDF-60XS955 Blue dots all over screen. Lower left corner of screen has a small blue cone shape. Will a new bulb fix this? If yes how do I replace the bulb?
It is problem of light engine (optical block) in TV and Lamp replacement does not solve it.
TV needs replacement of light engine, that is costly part.
Jun 20, 2009 | Sony KDF-42WE655 Television
Blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Jun 14, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
348 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
