Question about Ultra Linear UL-2200D Car Audio Amplifier
Power light on the amp goes on after 5 sec off ultra linear 1200
The problem. when i turn my stereo on ( is connected with the remote blue wire stereo & amp ) the power light on the amplifier goes on, after 5 seconds shuts off, i had run a 10 gauge wire directly to the 12 v battery in a honda civic.
also if i bridge the power + to the remote (in the amplifier ) it does the same turns on for a 5 seconds then off
( Ultra Linear 2600D 1200 watts amp )
  • Joel Friedenberg May 11, 2010
    What are you running off the amp? What speakers? How many, and what is the impedance(ohms) of the speakers, and what impedance is the amp rated at? Does the amp turn off after 5 sec. with the Volume down on the head unit and the gain down on the amp?
  • 3 Answers
If you run the remote from the battery you will need a on/off switch. Sounds like the amp is overheating. Also, I don't understand bridge the remote and power. They should be seperate going into the amp.
Posted on Mar 01, 2009
I have a kenwood stereo for 2000 saab 9-5. the tuner works but whenever i change it to cd you can no longer hear any music. it must be the wiring but i dont know which color wire is connected for the cd...
It sounds you are using an amplifier and using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on). Try hooking up the blue/white wire to turn your amp on. When leaving tuner mode, the blue wire shuts off, turning off the amplifier.
Sep 28, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a boss bass 1200 low profile amplified sub that isn't working. my power wires connected and receives juice, my ground is grounded, and my remote is hooked up. also my rcas are connected and the...
+ positive from battery ground is of course - anywhere on body put it on last.to avoid sparks if + is powered up! U can put a link between remote and positive it should then be on. Led normally goes blue rca s need a signal from stereo make sure its a amp out or sub out not an input on stereo set all knobs to middle and if speaker is connected to amp speaker + - it should be on, try an mp3 player with jack to rca for testing a known signal.amp may have loop rca make sure its on inputs.some have high inputs too using speakers wire stick with rca
Jan 17, 2018 | Boss Car Audio & Video
I have a power acoustiks ps2-1200 it has power but the red light is on indicating that its in protection mode for some reason any idea why
There is a short or wires are touching, Then again it could be because the remote(Blue wire) From amp to stereo which tells it to turn on and off has been connected to the wrong wire and is not working effectively.
Check for any shorts check all wires from both ends it shouldn't take long and make sure no wires are even slightly touching.
Aug 11, 2010 | Power Acoustik PS2-1200 Car Audio...
I have a linear amp 1600 I ahve power to it but it wont work and what is the remote wire supose to be connected to?
The remote wire is supposed to be connected to the remote output on the back of the head unit that is feeding the amp.
Without the remote wire hook up the amp will not turn on.
Reason for this is, the Head Unit tells the AMP to turn on, without the remote connected the AMP is going to do nothing, find the remote switch wire on the back of your Head Unit and run the wire to the remote input on the AMP.
Sep 16, 2009 | Ultra Linear UL-1600M Car Audio Amplifier
Wiring up a sub and amp
The acc means a power on connection when you turn on the key..On your amp you'll see a blue wire or a connection that says remote..Then find a connection on the car that when the key is turn on or when the radio turns on it turns your amp on for you threw that wire..Hope this helps you...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Apr 04, 2009 | Car Audio & Video
Car audio
on the back of he cd player is the wire harnest there should be a SOLID blue wire on there take the remote wire connect it to that and run it to your amp and put it where the amp says remote. there is an easier way you can hook up your power to the amp then take the remote wire and just run it directly to the power wire on the amp you should only need a couple inches of wire and it will work fine
Jul 10, 2008 | Kenwood KDC-MP335 CD Player
Amp
It should have a blue wire from the harness on the back of the player for turning on the amp, it may also be labeled "antenna" or "power antenna" or "P con". That is the one to run to the remote turn on of the amp.
Mar 10, 2008 | Phase Linear UDV9010 Car DVD Player
Alpine mrp-m450 Amp won't stay on
im having the same problem with my amp, I took it to best buy and they said the amp was recieving power and recieving signals from the deck and i had everything hooked up right but that in the circuit board all the connections were blown, meaning i have a blown amp, i hope this isnt your problem but it definetly sounds like it. GOODLUCK
Nov 12, 2006 | Alpine MRP-M450 Car Audio Amplifier
AMP turns ON then turns off
The power antenna wire only supplies 12vdc when the radio is on. When CD or other sources are selected, the power antenna wire goes to 0vdc. The remote turn-on wire provides 12vdc whenever the head-unit is on. If your amps are powered on only when the radio is turned on, I would bet that you have the power antenna wire connected and not the remote turnon wire.
Sep 11, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Ultra Linear UL-2200D Car Audio Amplifier Logo
265 people viewed this question
Top Ultra Linear Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you an Ultra Linear Car Audio and Video Expert? Answer questions, earn points and help others
