Question about Canon MVX20I Mini DV Digital Camcorder
Canon MVX250i Zoom Problem
My trusty (nearly 3 years, old so well out of warranty) Canon MVX250i has developed a fault and is now permanently stuck on maximum zoom, the zoom slider no longer has any effect. So with digital zoom off I'm permanently at 16x and with digi-zoom on 320x! It seems that the best course of action is probably to send to Canon or someone like Plymcare for repair, but before I do has anybody else had (and fixed) this problem? Is there anything I can do myself to save having to return it? I've been through the User Manual with a fine toothcomb and couldn't find anything helpful (e.g. if I had set something incorrectly in a menu somewhere). As always, sods law applied and I did not find the fault until the day of a friends wedding which I wanted to film, but fortunately he also had a Pro making a video so I still get to see what went on, all I have is a couple of minutes of very close up shots of the Groom and Best Man!!! Thanks in advance for any help.
  • 2 more comments
  • Anonymous Jan 11, 2009
    Just the same problem. It allways Zooms in to max tele
  • Anonymous Jan 26, 2009
    I have the very same problem. I tried to fix it. I unscrewed the plastic panel positioned over the beeper. Under the panel there is an FCB connecor (linked to the beeper) where a small flat cable is inserted in. I temporary fixed the problem just disinserting/reinserting the cable from the connector. But after a while the problem appeared again. The fixing method worked so many times (every time only for few minutes/hours) that I'm pretty sure that the problem is due to this connector but I'm not able to fix it permanently. It could be also due to a combination between a connector problem and the sliding zoom command not working properly but I have not been able to unmount that sliding switch (an internal screw make it impossible with standard tools).
  • davebreddy Mar 27, 2009
    Dave from Cheadle Cheshire, I bought my MVX250i when it was first launched, I have put about 15 tapes through the camera and the zoom has stuck. If cars are called in with a design fault why not cam-corders which are not used very much. These big companys do not care.
  • davebreddy Apr 12, 2009
    I am amazed - this worked for me !! thank you.
    Dave from Cheadle.
I had this problem on this camera. I found the battery removal rechnique seemed to work for only a short while, then the problem would come back repeatedly. I looked into just buying a new one but when I explained the problem to a salesman in an independent camera shop, he asked me if I'd just tried hitting the top of the camera. Apparently the motor sometimes gets stuck. Since the camera was virtually useless I tried this (hit it 2 or 3 times quite firmly, near the lens and by the accessory shoe). Now it zooms in and out perfectly and so far hasn't reverted to its problem state.
Must try to give the camera shop some other business - maybe when I buy a new stills camera
Posted on Aug 18, 2009
  • Rob_z32 Mar 12, 2011
    Fantastic! I've had this problem on and off for years. Sometimes the zoom gets stuck at full; other times it just slowly creeps forward and I have to keep pressure on the switch in the 'wide' direction to hold it still. I've had it 'repaired' three or four times but every time the problem has returned. I was repeatedly told it was the function block, whatever that is. Now, within two minutes of googling the problem, I found this advice. I hit the camera once and the stuck zoom was released but kept creeping. I hit the camera twice more and the creeping stopped. I'm delighted! Thank you for posting this tip.
Yeah, I had the same problem with mine...I changed the skin detail to soft and it miraculously fixed! It may work for you, it may not, but I'd give it a try.
Posted on Jul 24, 2007
Not accepting batteries we know are charged. Says please replace batteries and turns off. Its nearly 2 years old so out of warranty.
Are the batteries two years old? All things come to an end, and while Ni-MH cells are supposed to be rechargeable hundreds of times under ideal conditions, in real life they will lose a bit of capacity every time until they become a bit short of puff. You could try a couple good quality alkalines- if it won't run with them, then it's a real fault and you might as well buy a new camera. In two years they have gotten much better and cheaper.
Nov 28, 2010 | Canon PowerShot A470 Digital Camera
I have a canon eos 20d that has become permanently attached to a canon 75-300 zoom lens. I cannot detach the lens and fear if I force it it will break the camera and/or lens. The lens is more than 5...
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed. if it dint work let me know
Regards
Smilemaker.
Jul 08, 2008 | Canon Cameras
Powershot G6 -- Zoom button stuck
Does it display any of these messages
Dec 15, 2007 | Canon PowerShot G6 Digital Camera
Canon sx20 problem
Hi there, dont use it. Because its a problem of lens giude pin. May be its damaged or some how there is some dust stucked. 54e194c.jpg
Another few reason is below.
Low battery or damaged battery can't afford to give that much power to motor. Or see the image below for lens problem.
I suggest you try to clean as per your risk or visit a canon service center. Thanks.
Mar 17, 2010 | Canon PowerShot SX20 IS Digital Camera
On my tasco golden antler rifle scope, the zoom
Try spraying the ring with dry silicone spray. Warranties have changed. See the first link.
Product Warranties
  • Tasco Target and Varmint Riflescopes - Limited Lifetime Warranty
  • Tasco Propoint Scopes - One-Year Warranty
  • Tasco World Class Riflescopes - Limited Lifetime Warranty
  • Tasco Red Dot Scopes - One-Year Warranty
  • Tasco Pronghorn Riflescopes - One-Year Warranty
  • Tasco Rimfire and .22 Riflescopes - One-Year Warranty
  • Tasco Trail Cameras - One-Year Warranty
  • Tasco Binoculars - Limited Lifetime Warranty
  • Tasco Spotting Scopes - Limited Lifetime Warranty
  • Tasco Telescopes - Limited Lifetime Warranty
  • Tasco Microscopes - Limited Lifetime Warranty
https://www.lake-link.com/forums/Guns-and-Shooting/discuss.cfm/100501/Tasco-Warranties
Looks like France is your closest warranty option
Contact Us Tasco Believe it
Dec 19, 2017 | Tasco Golden Antler 3 - (9 x 40 mm)...
Downloading to computer from MVX250i Mini DV Digital
found proper port at front of camera which solved my provlem. thanks for yourinterest.
Jun 23, 2008 | Canon MVX250I Mini DV Digital Camcorder
Canon MVX250i Zoom
found the solution somewhere else on the net: just leave the camera lying with the batterie taken out for a while and it works again
Jan 01, 2008 | Canon MVX250I Mini DV Digital Camcorder
Zoom not working at all
You have a one year warranty with Canon, you should have all the information about shipping it to them in your original box.
Dec 17, 2007 | Canon PowerShot S3 IS Digital Camera
Error light & 7 beeps
geez, going back in time,but it is a print position fault, head is not traveling correctly , make sure rail is lubed and carriage can move back and forth without obstruction,
Oct 26, 2007 | Canon BJC 80 InkJet Printer
Canon powershot A300
Canon Technical Support on their website. I have come across this before with this model a funamental fault perhaps. But at three years- time for a replacement I think Try Canon web site support first.
May 28, 2007 | Canon PowerShot A300 Digital Camera
Canon MVX20I Mini DV Digital Camcorder Logo
850 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
