Question about Disney Cars 16-Inch Boys BMX Bike
I am trying to get the hand break attached
I can not fit the wiring from the tire into the actual hand break
  • 405 Answers
There is a screw in adjustment to allow you to install it, screw both ends if they both are adjustable, then you can reattach, after than screw each end back out to adjust. Hope this helps you! and Merry Christmas!
Posted on Dec 23, 2008
Hand break on my daughters bike won't release
check that the brake pads aren't catching on the rim or the tire, check that the brake cable isn't rusty inside the housing or corroded. check the bolt that attaches the brake caliper to the frame to see if it is too tight.
Apr 17, 2014 | Huffy Cycling
Removed lugnuts but a tire will not come off the vehicle . The parking break is off, but the rear wheel will not spin. I turned the ignition on and the parking break light was not on. I lifted the parking...
rear wheels on saturn's I believe have drum brakes - these can tend to seize up when worn through and the brake shoe rivets start to cut into the wheel housing or if not worn out, just be tight enough to keep wheel from spinning freely. Also the light on parking brake is a simple switch attached to the lever and is not reliable. I've had parking brake cables rust up and seize which can be a pain - generally requires a replacement cable and often the connecting yoke and rods.
As for the wheel not coming off - that's unrelated to the brakes - the brakes act on the actual wheel hub to which the lugs attach the wheel and tire. Many times it is problem of rust and dirt caked up between the wheel and the hub. I'd suggest rapping the wheel with a hammer, go all around the perimeter several times on the back side - use a piece of wood between hammer and wheel to protect the wheel from getting dented - the hammer "shocks" usually will vibrate thru the steel or alloy to loosen caked up dirt and rust. Can't think of much more you can do - maybe others have a suggestion. worst case might be to bring it to a tire shop and pay them $10-$20 to get it off - if it is just for inspection they can put it right back on for you. If you are looking to swap it out with another tire/wheel, then they will charge more since they often ding you for balancing it (which is a good idea regardless).
Jun 03, 2017 | 2008 Saturn Sky
3rd brake light not working,the other two are ok micra
The wires going into the right hand rear brake light has a red,green wire with a silver band. This is the wire that powers the 3rd brake light. Disconnect the wireing plug from the light fitting and meter out the red/green and silver wire from there up to the 3rd light, this will prove if there is a break in the wire ( most likely are is inside rubber grommets at tailgate hinge. ) This will prove the wiring. I got a spare piece of wire and ran a jumper cable from the silver track on the light fitting relating to the green red and silver wire ( top left track ) to the light fitting and another wire to earth, activated the brake and the light came on proving a break in the wire.
Apr 27, 2012 | Nissan Micra Cars & Trucks
I have a cannondale Q6 2010 and I had removed the saleman remove the front tire so it would be easier to haul in my car. He undid the breaks but when i got home I got the tire back on the frame but need...
after placing the tire in place simply take the brake glide elbow l and after squeezing the brakes together place it in the hanger its the floppy bar on the left side brake arm after fitting these together place the rubber boot on the remainder of the glide and voila your done :) this is based on a v-brake system that was simply opened and had not had cable removed if its another brake style simply leave a comment here stating so and ill walk you through another style if needed ok :)
Feb 26, 2011 | Cannondale Cycling
How to release the spare tire
I will tell you how to remove the tire but it is a difficult task, best done at a tire repair shop where they have a lift so they are not working on their back. There is a spring-loaded, wire actuated metal clip that holds the
spare from dropping.
It actually prevents the mushroomed end of the plastic sleeve on the
tire cable from passing. You have to loosen the tire, then reach in
with your hand and squeeze the clip with one hand, and angle the
plastic sleeve with the other to release the tire. After I got mine
down, I took the wire piece out. I think the wire piece was supposed
to be some kind of release, but it doesn't work very well.
Apr 23, 2010 | 1998 Dodge Caravan
What size tire fits my 2001 sts
you can fit as big as 20'' rims and tires
Jan 29, 2010 | 2001 Cadillac Sts
Differential problem
fit the factory size wheels ,not monster truck ballons
Dec 13, 2009 | 1997 Kia Sportage
Bmw 328 coupe number plate light only one works but if i change the units to the side that works both work but the right side don't work whats wrong! on the right side i tested the power and it rads 1.1 on...
It sure sounds like there is a break in the circuit to the right hand bulb. See if you can follow the actual wire back to where it goes into the loom. Possibly a push fit plug loose or out.
Oct 06, 2009 | 1999 BMW 318 ti
Brake assembly
I did no find assembly instructions specific to this model.  From what I see in pictures and descriptions it looks like a standard caliper brake on the front wheel.  The knob/plug on the cable should fit into a groove and hole on the brake lever if the cable is slack enough to make the connection.  You may have to loosen the cable tension nuts at the caliper and at the brake handle (labeled 1 & 2 in the instructions) to get enough slack.
Generic instructions are at: http://www.huffy.com/resources/pdfs/multispeed_manual.pdf
See pages 21-23 for instructions about adjusting the brakes.  You will have to do this after making the connection and it shows the various cable tension nuts that you can use to get enough slack in the cable to connect it.  If you loosen the cable tension nuts (1&2) enough you should be able to remove the cable from the slot through the housing, expose the attachment slot in the brake handle by pressing it against the handlebar, insert the knob/plug into the hole and then work the cable back into the slot in the housing.  Tighten up the tension nuts and make the final adjustments as described in the instructions.
May 28, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
Brake assembly
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
Dec 01, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Disney Cars 16-Inch Boys BMX Bike Logo
41 people viewed this question
Top Disney Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Donald Ayers-Marsh
Are you a Disney Cycling Expert? Answer questions, earn points and help others
