Question about GE 30" Self-Cleaning Freestanding Gas Range - Stainless-Steel
GE Adora Griddle Top replacement
I'm curious how much it costs to replace my Adora gas range oven griddle. It came with one non stick griddle that I need to replace, I can't find it on the web. I can't find my book for the part number, either.
  • 725 Answers
Part number for the griddle is WB31K10140
partstore.com has it for $87.95 hope it helps
Posted on Dec 23, 2008
Only two burner are igniting
Posted on Mar 06, 2010
I just purchased a GE ADORA range and during the installation I scratched the control panel, any idea if the control panel can be replaced?
Posted on Mar 06, 2009
Griddle top replacement
well this is different, but sounds like fun. I would just Repair the gas griddle you have. from the sound of it you need to replace the 3 or 4 tstats that control the griddle. If you are in a Metro area you can find a dealer for Robert Shaw and get the parts you need. but you may also start at http://www.garland-group.com/. everything there will be newer but you will be able ask about where the data plate is and then get parts lists. call a small comercial kitchen repair company and ask for help there too.
Jan 29, 2012 | Garland Ovens
How do I use my Griddle for the first time? We did not get a manual I would like one sent to us.
I can't help you with the manual because you did not provide the make and model number.
Typically, you wash the griddle with soap and water (DO NOT WASH ANY ELECTRICAL CONTROL UNIT!). Rinse and let dry if it has a non-stick coating. If it does not have a non-stick coating (bare metal), towel-dry the griddle, then put some vegetable oil on a paper towel and wipe the entire cooking surface so it is covered with a thin film of oil. Heat it to about 250 °F for about one on-off cycle on the electrical control. It is now "seasoned" and ready for use. If the griddle does not have an electric heater but is designed for use on a range-top burner, set the burner to just below medium heat and heat until water droplets splattered on the griddle boil off quickly.
May 30, 2011 | Microwave Ovens
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Does my griddle pan on my Frigidaire 5 burner
I just got a new range and the instructions to season the griddle are in the instruction book. Wash an d dry the griddle. coat all surfaces ( top and bottom ) with a thin coat of cookin oil. place in oven at 350F for one hour. turn off afer an hour and let cool in the oven.
Jul 02, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
I am looking for a replacment part for a 3 year old General Electric Gas Stove. The part I want is the grill that goes on top of the cooktop between the burner, whis is used for cooking items such as...
Your looking for the griddle.
I am not sure if this is the exact part your looking for due to the model number listed in your post does not have one as a parts replacement. If you have a good model number I can probably find a source for the part.
Here is one GE griddle:
http://www.appliancepartspros.com/Appliance-Parts/GE-Griddle-item-number-AP3205515.aspx
If this is not what you were l;ooking for please provide a model number so I can better help you.
Thanks for using FixYa!
Kelly
(it may not be the one for your range but it is one of 2 types they used)
May 18, 2010 | GE Adora JBP77SMSS Stainless Steel Kitchen...
GE 40" range griddle
You will have to check GE. With a model this old, it will be hard to find a replacement.
Feb 11, 2009 | GE 30" Self-Cleaning Freestanding Gas...
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
GE 30" Self-Cleaning Freestanding Gas Range - Stainless-Steel Logo
1,560 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
