Colume? Did you mean "steering column"? as in steering wheel? Usually turning the key in the ignition as you turn the steering wheel will unlock the steering column. This may take some considerable force depending on the way the car is resting (on a hill, against a curb, with sideways pressure on the wheels).
Being more specific your problem will always yield a more helpful solution.
We just unlocked a 98 Volvo S-70 radio,on the front,you have 2 slots across from each other,use you finger nails or a dime to get it to come out,then you can pull it out,then get the serial number and write it down,then put stereo back in,then get your vin number,it's on your insurance card,then call dealer and ask for your radio code,they will ask for vin number and radio serial code,if your radio says code,then you can enter it,ifit says off,then it's locked,you have 3 tries till it locks and it says off,if it says off,then you turn key to number 1,turn radio on,wait 2 hours,then it will say code,then enter code and radio will unlock,our code is 5513 if you want to see if it will work for you.Here's a link to you owners manual,read about the radio code,same as our's,but the dealer will give it to you free. 1994 Volvo 850 Watch this video. How To Find Volvo Radio Code 850 960 S70 C70 etc
Sometimes the electronic control module goes to sleep. Usually happens when you always unlock the car with the remote. Trying locking and unlocking the driver door several time to see if it clears up.
It is a security feature. There is a trip wire in the side panel on the wagon (interior), and in the trunk on the sedan. That will get it open. You can also disconnect the battery for a few minutes, then reconnect, and lock and unlock the car with the key and it should re-set. The release wire information is in the manual, keep looking.
You will need to turn the ignition to the number 1 position and turn the radio on. It can take several hours, but the word code should come back on. When that happens, you will need to put the correct code in. If you don't have it, a Volvo dealer can give you the correct code from your VIN.
I had the same question when I got my 94' 850 Turbo wagon. I kept wondering where the fuel door release was. To my surprise there was not one, you simply must have the entire "CAR" (not just the drivers door) unlocked. Use the key FOB. After that, go to the fuel door outside the vehicle and push in on it to pop it open. Hopefully you have not run out of gas yet.
remove radio by pushing in the two side tabs to alow you to remove. Call your local volvo dealer (parts dept.) with the serial # and part # off the radio. Type in the code and volia.
do you have a cd changer or is it the cd/radio .just a thought the cd button on the radio will only work of you have a changer fitted usually in the boot
