Question about Kohler Home
When water level is above the handle on the wall it goes down
Just bought a Kholer normal bathtub-soak, when I fill the water and the water level is above the stain cover (on the tub wall, on which there is a handle to control the water go down or stay in tub), the water will leak from the gap of the cover (there is a gap on the rim of the cover), why there is gap on the cover? How to stop the water going down from the gap because the water in the tub is not high enough to soak the body.
The cover is called a trip lever and Over flow to stop you from over filling the tub or when you get in the tub to equalise the water level. And prevent water from pouring down on the floor
Posted on Dec 26, 2008
Bathtub wall was cut short and is leaking to downstairs when we take showers
Fill the space with liquid foam filler made for water areas. this will seal and fill the space, keep it below the surface as it does expand and will go above the tubs line. let it dry the recommended time and cut off the excess with a razor blade. once that's done then you can caulk normally to hide the foam.
Nov 21, 2013 | Home
The wall of my bathtub was cut too short and water leaks to downstairs how can i fix it
fill the space with liquid foam filler made for water areas. this will seal and fill the space, keep it below the surface as it does expand and will go above the tubs line. let it dry the recomended time and cut off the excess with a razor blade. once thats done then you can caulk normally to hide the foam.
Nov 21, 2013 | Home
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
US Parts Center
Mar 17, 2013 | Ariel Platinum AM128JDCLZ Whirlpool...
After flushing the tank fills up then the water level gradually goes down then fills up again
Hi rim7297...
Your "flapper valve" is leaking by...replace the flapper valve and your leakage problems will be no more.
Please take time to rate me
For a video on how to replace your flapper valve go to this website:
Sep 17, 2011 | Home
I bought an American Standard toilet about 3 months ago, ever since it was installed (by me) the water in the tank continues to run like its trying to fill it up. I have tried numerous time to adjust the...
There are several things you can check. Make sure that adjustment on flush handle to flapper is free and not binding and holding flapper open.Make sure that seating surface for flapper is clean and does not have any rough spots on it.If it does you can empty tank and dry it off then sand any rough spots with sandpaper. Also make sure that tube from flush valve to overflow tube is not below water level in tank when it shuts off as this can cause it to syphon water out of tank and refill. If it needs to be trimmed then cut tube so it is above water level in tank. Hope this helps. Thank you.
Jan 15, 2011 | Home
My kholer jetted jacuzzi tub will not come on or do anything...just bought this home and to the best of my knowledge worked prior to.
make sure there is power to the pump. Some of their model require you to be in the tub full of water before the pump will turn on.
Dec 16, 2010 | Kohler Home
The toilet refills to the overflow tube and then keeps on pumping water. It won't stop until I press down quickly on the top of the black Phillips-head plastic screw that's labeled "water level...
Carefully take a hold of the rod that goes to the ball and bend it so the ball points down further into the tank...this will get the water to stop then before it goes over the top...
If the ball is heavy and is full of water then you need to replace the whole fill valve...
Sep 16, 2010 | Home
Hi,I have a Bathtub Shower Valve that is not working
Apr 20, 2010 | American Standard Home
How to clean out jacuxxi bath pipes
All Jacuzzis have a suction fitting. I do not which cleaning solution you are using but most require that you fill the tub to at least 4-6 inches above the suction fitting (some require hot water and some don't specify) then add the appropriate amount of cleaning solution and then for a specified period of time. The suction fitting is the only way to get the solution into the piping; unless you have a professional plumber do it. If you have any questions please ask.
Jul 31, 2009 | American Standard Reminiscence...
Simpsom Washing Machine
First see that the exit hose behind the machine is at the correct height, before coming down into the wall standpipe or your sink. Your machine pump pumps water over this height, about 2.75 feet above ground level. Possible there is a water level height marked behind your machine.
If water flows out when machine is off, possible your inlet valve at top of machine is defective...............can be replaced easily.
Mar 22, 2008 | Washing Machines
Home Logo
112 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
