Question about GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer
Spacemaker spin cycle problem
My spacemaker started making a loud squeaking sound during the spin cycle. It also does not drain completely. The wash cycle seems to run well though. What do you think?
  • brosello Dec 24, 2008
    would that explain it washing correctly but not draining appropriately? If I do open the cabinet should I disconnect the hose from the pump and see if something is stuck? What and how could something big enough get there in order to clog it?
  • 725 Answers
You may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Posted on Dec 23, 2008
  • Franklin Ouchida
    Franklin Ouchida Dec 25, 2008
    yes you can. But it most likely on the other side of the impeller...a lot of stuff can get over the tub and into the outer tub... good luck
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Loud clunking, banging sound during the spin/drain cycle.
the make , model and year are missing but if it is a top loader unit , it indicates that the tub suspension bar motion absorbers have broken and need replacing
Sep 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
When the washer is in the spin cycle it make a loud squeaking sound
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | Maytag PAV2300 Top Load Washer
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
WASHER MAKES SQUEAKS AND SOUNDS REAL LOUD DURING
it could be a split pipe but its far more likley to be the drum bearings on the way out thats why its so loud and thats also were the water is coming from as well
not a cheep repain to get done,,,
sorry for the bad news
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Very loud rumbling noise during spinning
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
GE WSM2480DWW Unitized Spacemaker Washer and Gas Dryer Logo
276 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
