Well my router has all the lights light up accept the wireless light how can i fix that without messing up all the other connections?
  • Vern Haynes
    Vern Haynes May 11, 2010
    you need to enable the wireless part of the router. What is the make and model # of your router?
  • 4 Answers
Type in 192.168.0.1 OR 192.168.1.1 OR 192.168.2.1. Whichever works.
If none of the IPs work above, go to Start > All Programs > Accessories > Command Prompt (Start > Search: cmd if Windows Vista. Make sure to right click and run as Administrator)
When the black box comes up on the screen, type in ipconfig and press enter. Type in the Default Gateway into your web browser.
You should be directed to your router configuration page. Look for any options such as Wireless, or anything similar. Make sure it is enabled, and mark down your network key.
Posted on Dec 24, 2008
Wireless light flashes & can't connect
Are You Sure You Have Signal coming into modem/router sometimes the red light indicates no connection is it dsl or cable or? if DSL can you use the phone disconnect the filter. and plug the cord strait into the wall plug.cable could be the connection check for shorts could be an issue with your carrier call them for a simple electronic reset Hope this helps!
Jul 26, 2017 | Belkin Components F6D4230-4 Wireless...
The wifi isnt working. the wifi light is flashing along with the wired computer lights and internet lights. the power light remains steady
Has this ever been used as a wireless 'extender'? If so, you will need to switch this feature off, so that it will accept connections from clients instead of only from another wireless access point.
Oct 16, 2010 | Belkin (F5D7230-4) Router (587009)
So I got this Belkin router (N) and the wireless light just comes on and goes off as it feels what up?
On my Belkin router the wireless light only light up when somebody is actually connected using wireless - it also flashes orange when somebody is trying to connect but failing - my router is a F5D8236uk4
Feb 27, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
My internet light is blinking but it won't connect
Depending on the make or router, the internet light may just signify that that an internet signal is detected and not that it is actually authenticated to use the internet. If you can get to the diagnostics or log page of the router and look for 'Chap authentication'. If this has failed then the username and/or password is not being accepted by the ISP.
Dec 15, 2009 | Dynex Enhanced-G Wireless Broadband Router
Wireless indicator light doesn't light up and
The "Wireless" light doesn't indicate that wireless is available, it indicates that wireless is being used.
You need to narrow down your problem statement by what symptoms you are seeing. Does your PC "see" the wireless router? Does the router accept your connection password?
Then follow the troubleshooting script in the user manual at
http://downloads.linksysbycisco.com/downloads/WRT150N_ug,0.pdf
Nov 25, 2009 | Linksys Wireless-N WRT150N Router
On my wirless rounter i have every light on accept for my wirless light, could you please tell me what i'm during wrong
Hello mate,
you will need to connect your computer via Ethernet cable to your router and then access to the router web configuration page and check if the wireless is enabled.
If it's disabled, it's a good news. you will only need to enable it and it will start working.
if it's enabled, in this case there are two possibilities: 1. the wireless is working and it's only the light which is not working, you can verifiy that by scanning wireless available from your pc and see if your router appears in this list.
2. the wireless function is brooken: in this case, you can try to do a reset factory, but this doesn't help you will need to contact your reseller and i hope that the router is still under warranty because it will need a repair or exchange.
Best Regards,
Oct 31, 2009 | Belkin N1 Vision Wireless Router
It just stopped working.
first discovnnect all cables .then power up the router .then see in backside one reset button.press that button for 10 secoonds.
it reset to factory defsults.
then it working but may be u hace configure aagan your router.
che k both link to configure router.
http://192.168.0.1 and http://192.168.1.1
then type admin and pasword aslo admin if pasword is not accept then left it blank.
Nov 15, 2008 | Apple AirPort Extreme Wireless-N Wireless...
Can't connect via cable, but wireless works fine
seems you are using winXP-P. Your firewall might be blocking it. Or your virusscan program might be blocking it. Come back after disabling these features and trying again.
Oct 09, 2007 | MSI RG54G2 Router (MS-6848-002)
Computers & Internet Logo
Alun Cox
David Payne
David Payne
