Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon mp130 error message ...wrong cartridge
Was using cleaning process in maintenance tab and the error message wrong cartridge appeared and will not clear.
  • 121 Answers
SOURCE: Service Error 5100 on Canon MP150
you can also uninstall and reinstall printer drivers if you have the cd or visit the manufactuarer's website and download those drivers.. be sure to reboot after uninstalling them too.. if you need additional assistance let me know...
also check to be sure the printer cartridge is all the way in too..
that's helped many others as well.. also try taking the cartridges out and shake them for a few minutes, reinsert them and reboot everything.. let me know what worked out for you..
good luck,
d
Posted on Mar 09, 2008
SOURCE: "Clear paper jam" error, but there is no jam!
try open the gear mover paper is slip. i have fix the problem same.
Posted on Apr 06, 2008
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
yooperbud
  • 8637 Answers
SOURCE: canon s4500 wont recognise bj cartridges
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
SOURCE: ink cartridge jammed
Canon FaxphoneB95 gives message"Cartridge Jammed". How can I solve this problem. Need Answer Urgently Please.
Posted on Feb 06, 2009
My Canon Pixma MP130 keeps giving me the 5100 error. Can't even complete the nozzle print test. The ink cartridges do not appear to be jammed as they move. What is the problem? Please help.
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps!
May 22, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I just bought a Canon MP250 and everything seems fine, but when I go to print, all I get is a blank page.
When the printer is new, there is "tape" over the new printer cartridges to avoid leaking during shipping. Remove the cartridges, make sure the tape is removed from each and replace the cartridge. I hope this helps. If not, you may need to try a few cleaning cycles from the maintenance tab in the windows printer PROPERTIES dialog box. After the cleaning cycles let the printer sit 20 minutes then try to print again.
Jan 23, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp130 service error 5100 - won't print
Turn off printer.
Hope it helps!
Dec 17, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
I changed ink my printer showing wrong cartridge
Make sure you are using factory new Canon ink cartridges.
If you purchased re-filled cartridges or third party cartridges that is most likely your problem.
Don
Jun 14, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Says more than one yellow cartridge is installed
you may recover the printhead by unclogging it. Follow these steps to unclog the printhead:
  • Right click in the printer driver name
  • Select Properties menu
  • Click Maintenance tab
  • Click on Cleaning sign for regular cleaning. Perform this up to 3 times.
If this does not work, perform Deep Cleaning
May 30, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP130 error 5100
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 printing blank pages & cartridge jammed message
Hi You can Try
Error Code 5100 Yes see lots of this errors
Solution 1:
Solution 2:
Mar 11, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink cartridge jammed
Dec 14, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
180 people viewed this question
old marine
old marine
