Question about Garden
I have a poulan 2550 40cc that won't run in idle
I have cleaned the entire unit and all filters and have used new gas
Possibly the spark plug, idle screw is set too low, air getting into the fuel line. Does it run at higher speeds but kills when trigger is released?
Posted on Dec 23, 2008
My poulan won,t start ,i put new primer bulb on and new gas lines nowit won,t start
Flush old gas. Clean or replace spark plug. Check float on carb, clean carb bowl if equipped.
Jun 03, 2015 | Poulan Garden
My poulan 4018wt has been a hard starter from new. It started to act up out of the blue and started shutting off halfway into the cut and didn't always want to idle right. So I changed the spark plug,
I'd say the most probable culprit is the fuel.... I'd first try dumping the tank out, mixing fresh gas with the addition of a fuel stabilizer and start the saw. It'll quickly vent any old gas in the line and should begin to run fine with the new mix. If not, consider returning it to the service center for adjustment.
Never use gas that has sit on a shelf for months at a time as it becomes 'stale' (for lack of a proper term). Todays 'formulated fuel' can be a cause a bit of a problem for some small engines. Anytime you refuel, shake the can to remix prior to filling.
The oxygenated nature of the blended gas sometimes causes the chain saws to run a little 'lean'...meaning too much air to fuel ratio which could be a portion of your problem. A lean running saw will run hot and scoring of the piston or cylinder wall is possible. Some finely tuned professional saws need carb adjustments between the summer blend and the winter blend gas.
Mar 24, 2015 | Poulan Garden
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
Jul 27, 2014 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Won't idle, cranks and runs fine as long as trigger is depressed
Could be just a carb adjustment required, the L screw on the carb will richen up the mixture, if increaseing the the idle screw does not help, try extra 1/4 turn out on the L screw, make sure the air filter is clean before makeing any adjustments.
Feb 12, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Will not run at low idle
Fresh gas.new fuel filter and fuel lines and clean carb and screen and make sure your diaphrams are good, preset your jets 1-1/2 and run and fine tune once you get it going, also check your exhaust port and screen for being plugged
Dec 08, 2011 | Poulan Garden
Poulan 446t Will start, won't continue to
The diaphragm in the carb is likely ruined from the gas gelling onto it. This will put pinholes in it and then it won't work properly. Pick up a carb kit and rebuild it (if parts available) and then you should be good to go. If you can't rebuild the carb, a replacement will run you 30 bucks or more.
Aug 21, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan p3314 chainsaw. It has been sitting up for a while. When I started it, I could not get it to run beyond an idle. Every time I squeezed the gas, it quit. Finally, it quit and refused to...
The ful line actualy disloved and the problem is inside the carburtator there is a valve that lets fuel into the fuel bowl and also shuts it off when its full the floats control it so its always opening and closeing that is stuck closed from the melted fuel line you need to clean the entire carburator out the neddle valve may have a rubber tip at the seal point so take care not to damage it ware it makes the seal but its not hard to do anyone with some common sence and a little mechanical abilitly can do them selves
Nov 23, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Idles fast, won't cut wood, stalls under load
Clean the fuel filter, air cleaner and muffler if clogged. Check all fuel lines for condition--replace any with original rubber lines--not plastic. The carburetor sounds like it could use a thorough cleaning and re-kit. It's somewhat common for saws to leak some bar oil over a long period. Good luck!
Jun 11, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
One year old Poulan weedeater starts right up but will only run with choke about half way on. Warm it up that way but it does not run any better. New gas, new spark plug, clean air filter. The weedeater...
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
