Question about Garden
I have a poulan 2550 that won't idle what could be the problem?
Poulan 2550 40cc
    Scholar:
  • 149 Answers
Try the L mixture screw, turn it in slightly if the engine speeds up it was too rich if it bogs down go out slightly un till it starts 4 stroking.
As a starting point both screws set to 1 turn out from just seated..if the high speeds ok dont touch the H screw.
Posted on Jan 12, 2009
How long should the juel line be on a 40cc poulan
A fuel line should be long enough to teach from where it attaches to the carberator to the fuel tank but not quite touching the bottom - however the line in the tank end should have a small filter on it. You should be able to buy a replacement line for your specific saw.
Dec 11, 2014 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Can i get a .325 sprocked for this saw
http://www.jackssmallengines.com/sprockets_poulan.cfm
According to this list of sprockets, the Wild Thing has a 0.3937 drive shaft and they do list 0.325 sprockets with that diameter shaft, but not for the Wild Thing. Doesn't mean they won't fit but you can call them and ask if there is any other reason it won't work. May be an easy cross. Good luck!
Sep 16, 2012 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
What kind of tool do you use to adjust.
they have a tool for that crappy little hole you have to get to adjust the idle screws. Or u can use a deep socket same size that work's also
Jan 02, 2011 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Chain won't stop when throttle pressure is released.
Start the engine and allow to warm up. Turn the idle speed screw (not the jet screws) CCW to reduce engine speed until the chain stops even hinting at running. If you get it too low, the engine will tend to die when it idles. Hope this helps!
Nov 25, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Need air / fuel mix and hi and low idle settings for poulan preditor
Your manual says 40:1 (1 gal premium/3.2 oz quality 2-cycle oil). If you are going to tweek it anyway use 50:1 (1 gal premium/2.6 oz quality 2-cycle oil). Clean the air filter first. Lou
Nov 14, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
I have a poulan 2550 40cc that won't run in idle
Possibly the spark plug, idle screw is set too low, air getting into the fuel line. Does it run at higher speeds but kills when trigger is released?
Dec 23, 2008 | Garden
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
