Question about HP (D7580-60003) Motherboard
Motherboard issue My HP DV9000 Laptop is having an intermittent problem booting up. It will sporadically turn on but then when it goes into a "safe" or sleep mode it will not come back up. The lights will turn on at the top of the keypad and the fan will start but then it will shut down and will not come back up. Help please.
  • Anonymous Apr 20, 2009
    My laptop is 16 months old and also recently experienced a motherboard failure. It is out of warranty by HP, however, since I made my purchase with my Mastercard, they double my mfg warranty. Giving me two years. Mastercard is going to reimburse me the cost of replacing my motherboard to fix the problem. WOO WHOO!!
  • HP Master
  • 5,660 Answers
It's a power issue. The battery is flat. (No charge present) The AC adapter (Charger) is plugged in. The DC Power Jack has an intermittent contact. (The DC Power Jack is where the AC adapter plugs in. The charger)
The DC Power Jack is broken itself, or where it's soldered onto the motherboard, the solder joint/s are broken. This gives an intermittent contact. To see if this is the issue, try holding the plug for the charger over to one side, when it's plugged into the laptop. You may have to move it side to side, or up an down, to see.
If this is the issue, the DC Power jack costs about $6 bucks. The cost to replace it is $120 to $150.
The tech has to completely disassemble the laptop, until just the motherboard is in hand. The old DC Power Jack is unsoldered, and a new one is soldered in. Then the laptop is reassembled.
IF, you can find a shop! Most of the time the entire motherboard is changed out. Now you're talking Ducketts! $$$$$$$
Posted on Apr 17, 2009
Brummer@marktwain.net i have a HP DV 9000 and when i turn it on the lights light up and then shut off , i can see the fan trys to spin. thank you for your time.
I have few suggestion to check whats going on.
Try to turned off your computer just pressing the power button.
remove the external devices connected such as usb, ac adapter and the battery, then push the power button again for atleast 15 secs, to drain the remaining power.
return the ac adapter alone then turn on the computer.
if still the same repeat the instruction above but instead once you turn on your computer go to bios. If still the same my suggestion is to contact HP as this is a hardware issue, however if that works then turned the computer off then go to safe mode, if that works restart the computer again. If it boots then nothing to worry, if it didnt work some software or driver causing the issue.
How to boot to safe mode: turn on the computer and hit f8 as soon as you've seen the computer logo.
This link will give you an idea about your system.
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
I hope this will help you resolving your issue.
Thank you for choosing fixya
Mar 02, 2011 | HP Pavilion dv9000z Notebook
I have HP DV9000 laptop when i switch on it powers but the display is like in safe mood i cant see anything
i am mr john uche aaron
in Nigeria ,
my hp pavilion dv 9000
cannot bootup
but display only light on the quick bar
and blank screen
what is the solution
Dec 12, 2010 | HP Pavilion dv9000 Motherboard
HP Pavillion dv9000. Intermittent stops. Cannot restart, but will do so after many hours. Screen turns blue with band of torn blue that looks like shutters. System carries out repair check - once worked...
Try booting your computer in safe mode... when your machine starts press F8 and go to Windows. Run for a couple of hours and see if this problem happens.
If you have system restore running, restore back to a point when you didnt have the problem
May 17, 2010 | HP Pavilion dv9000z Notebook
My pavillion dv9000 laptop will not boot When I try to turn it on, the power turns on but it turns off by itself and turns on again and repeats it over again. I found out that other people are also having...
dv2000/dv6000/dv9000 recall
I have an out of warranty dv9000 and haven't had wireless for months. I just discovered HP issued a recall for the wireless and other problems with several different Pavilion and Presario models. For the wireless problem with the dv9000 they are replacing the motherboard on all notebooks in or out of warranty. I was wondering if anyone has had the repair done under the recall and how it turned out? I'm also wondering if HP is still cosmetically trashing notebooks when they are sent in for repair?
Here is the link for the recall:
http://h10025.www1.hp.com/ewfrf/wc/d...842189&lang=en
Mar 03, 2010 | HP Pavilion dv9000z Notebook
My laptop screen is black. All light across the
Do you see the BIOS boot up phase, which is the bit in the beginning of booting the computer where you see DOS like white text on a black background?
If you do, there is a good chance that your problem is as simple as a Windows configuration issue. If not, you may have a short in the wires that connect the screen to the motherboard.
The first thing to try is to connect the computer to an external monitor and see if it will display.
Next, try booting in safe mode.
Then try booting from a CD.
It is possible to replace laptop screens, but it is usually not worth it.
Dec 02, 2009 | HP Computers & Internet
Hp dv9000
HP has identified a hardware issue with certain HP Pavilion notebook PCs, and has also released a new BIOS for these notebook PCs. There is a free repair if there are hardware issues. http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=1842189&docname=c01087277#
Jul 05, 2009 | HP Pavilion dv9000z Notebook
Hp pavilion entertainment pc dv9000 boots up intermittently,
Boots up? (your title was too long) Please post back details
Disable hibernation.
1. Click Control Panel
2. Click Power Options
3. Select the Hibernate tab
4. Uncheck Enable Hibernation box to disable
5. Click OK
Will help with boot issue as soon as I get the details back
Please rate this a fixya
Feb 11, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavillion DV9000 ''Checkered Screen''
Yes it is a hardware problem not a software one perhaps replacing the monitor Im afraid nothing else will suffice...
Nov 11, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion dv9000 Problem
I understand that your Notebook is not booting into windows.
To isolate the issue please try to boot the Notebook in Safemode.
Restart the Notebook and keep pressing F8 key and select Safe mode to boot.
Please try to perform the following steps also
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If your Notebook is booting into Safemode. Then try to restore the Notebook to factory settings. Before restoring the Notebook backup your data.
I hope this will work.
Thanks
Aug 12, 2008 | HP Pavilion dv9000z Notebook
DV9000 issues
hey, so ir dv9000 doesnt boot to hp logo screen & restart itself,first replace the cmos battery if thisdoesnt solves ur problem, the next time u boot check whether the rj45 & the dial up port give a led flash on start or not ,if not then u may have hape board ,cpu or power problem ....which can be fixed by repair only.
Nov 30, 2007 | HP Pavilion dv9013cl Notebook
HP (D7580-60003) Motherboard Logo
210 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
