There is an alarm/siren noise coming out of my alienware computer when i play a game.
Check the BIOS for temperature alarm and also check the temperatures that your CPU is reaching during a game by using a program like Hardware Monitor
Posted on Dec 23, 2008
The systems is working fine and no indications or warnings on the panels, but you can hear the siren at a low sound at all times. All the zones are working according to the panel and alarm monitoring...
The siren should not receive any power when in idle mode (non alarmed state). If you hear any noise, it receives some kind of low voltage. Is it powered straight from the panel or with external power supply and aux. relay? In any way - use a volt meter and measure across the sirens power terminals. If you have any voltage present check the source.
Nov 18, 2013 | Honeywell Ademco Wave 2 Wave2 Sirens For...
Loud beeping noise on alienware computer
by fb_margostanley.jpgmargostanley Aug 10, 2012
  • Thankk you. I fixed the problem. It was a key that was stluck. but others may want to know that the type of cement I used for the hinge was JB weld. Worked beautifully! thanks for all lyour help
  • Aug 08, 2012 | Alienware PC Systems Alienware Aurora High...
    Performance Teknique Icbm-7071 Everything on my alarm system is working, but now the only thing that will not work is the alarm sounding off. My receiver still beeps when my alarm goes off, but the car...
    Sound like the siren. check the connections at the siren. If the connections are good and the system is sending a signal then, you may need to replace it.
    Jul 27, 2012 | Car Audio & Video
    Good morning. my pc and 'an Alienware Aurora desktop and the problem' in the system fan turns to more 'of 1200 rpm using online games and the noise and' annoying. when the PC happens to all...
    Good Day Ilreleonebia!
    You should try cleaning all the fans inside your PC once in a while.
    Fans, especially in your video card would spin faster whenever you used the video card performance by playing online games that rely on graphics.
    It is very normal. What is not is the annoying sounds you are hearing. It should not be. These sounds is cause by dirt accumulating on your blowers and fans. Just clean and the annoying sounds will go away.
    Jun 09, 2011 | Alienware PC Systems Alienware Aurora High...
    Can't make car alarm go off. had to disconnect battery
    Chevy car alarms turn off with ignition and reading the transponder from the key or by turning the key in the driver door to the unlock position. If this does not turn off the alarm it maybe an aftermarket alarm. Is it a horn making noise? or is it a siren making noise? Horn usually is fatcory alarm and siren is usually aftermarket alarm. If it is aftermarket alarm then you just have to find the alrm module and unplug it.
    Feb 02, 2011 | Chevrolet Tahoe Cars & Trucks
    Speakers (M/N S-0264B) make a siren sound in most computer games
    Hi there bud , This is strange , It could not be your Speakers...ARe you sure its not perhaps your Anti Virus or something, like a 3rd party program your running in the back well you play???
    Hope you come right
    Happy new year
    Jan 06, 2010 | Audio Players & Recorders
    a connection may be faulty on your siren or car horn you can find the manuals at under support then choose manuals and manuals again you have to use the model number from under your dash not the remote because they may be different if that does not work you can contact their tech support at 800.998.6880 ext 210
    Oct 02, 2009 | On-Guard Alarm with Wireless Siren, Remote...
    Just installed smart siren kit, worked ok for 1
    Harley alarms, while a decent alarm system, are notoriously hard to set up. On a new installation I have sometimes had to run the set-up routine 4-5 times. I hope you have an owner's manual and/or good instructions. Keep trying to set the alarm up from the beginning. If you miss a key or time limit it's not unusual to have the set-up fail and you have to start all over. Disconnecting the battery will screw things up, so be careful.
    Oct 02, 2009 | 2002 Harley Davidson FLHTCUI Electra Glide...
    Hi lo alarm siren when playing online games
    Hi stretcharm_2,
    It seems that the hi-lo siren from the mobo indicates that the cpu is over hated.
    1st of all, you need to go into the BIOS/CMOS setup to check if the temperature was boosting higher that the prefix alarm. If it's low, but gone up very fast after a few minutes, you need to update to the latest BIOS firmware, as it's part of the Fatal1ty problem.
    you can download the bios here, be sure to read all the instruction before you proceed to update the BIOS firmware.
    you can always come back here and post a comment if you r no sure.
    2nd of all, you need to check is the heatsink was fixed properly.
    It's not your fault that's the fan wasn't fixed properly because the stock LGA-775 socket T heatsink's design wasn't a perfect one, and it has 4 very fragile fix-in clips. You need to check if all four clips were fixed firmly in the braket for maximum heat dicipation. It might be broken and you need to replace with another one.
    You might need to replace the thermal paste to a better 1.
    Please check your manual on how to diassemble the heatsink.
    Good Luck,
    Don't forget to rate my solution, thanks!!
    Jan 17, 2009 | Abit IC7-G Motherboard
    Siren noise from drive
    Sounds like drive is about ready to take a break for good mite need to install a new one. lala linda
    Jun 03, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
    Computers & Internet Logo
    375 people viewed this question
    David Payne
    David Payne
