Question about Kenmore 53532 / 53534 Side by Side Refrigerator
Fridge stopped colling both sides, fan runs only, soft click soun
Could this be relay/overlaod switch?
    Scholar:
  • 126 Answers
YES IT COULD BE. THE COMPRESSOR IS IN THE BACK KIND OF ROUND AND BLACK. THAT PARTIS LOCATED ON THE LEFT SIDE OF THE COMPRESSOR. REPLACEMENT PART # 12002782
http://www.searspartsdirect.com/partsdirect/getPart!search.pd?partNumber=12002782&pathTaken=partSearch
Posted on Apr 25, 2010
Compressor starts then shuts off, will not cool
You might need relay overlaod at bottom attach to compressor
Mar 08, 2015 | Refrigerators
Tssu-36-12m-b unit no cooling
Generally when the overload starts tripping the compressor is telling you it has failed. There is a relay that plugs into the compressor electrical connections and a start capacitor that is attached to that relay. Its a relatively low cost adventure to replace those 2 components maybe 30 bucks at the supply house. Otherwise if the condenser is clean and the condenser fan is running and the component replacement doesn't help you're going to need to buy a new compressor. Hope this helps and good luck.
Apr 30, 2014 | True Refrigerators
Compressor locked on Franklin FWC36 wine cooler. won't start. current relays bad. is it possible to get spare parts or nhot?
you might be able to get one at the junk yaqrd or dump
its a relay overload on the compressor
look back at the compressor
there should be a block on one side that the relay and overlaod
go to repair clinic they sdhould have what you need
Oct 07, 2009 | Franklin FWC36 Wine Cooler
Compressor gos to overlaod
sound like a bad start capacitor,if you have a capactance check on your multimeter,you can find the readings on the side of the cap.I always replace the relay,overload and capacitor at the same time. this usually keeps me from coming back and having to replace another part in a short amount of time. Also check and make sure your condensor coil is clean , let me know if you need more help
Mar 31, 2009 | Turbo Air 49 cu. ft. / 1388 liter...
Buzzing sound
sounds lkke a badcompressor, the overlaod relay is "buzzing trying to start the compressor. if unider 5 years it should be coverd under manufactures warr.
Jan 11, 2009 | Frigidaire FRS3R5EMB Side by Side...
Our electicity went out for a couple of minutes yesterday. Ever since then, the refrigerator side of our side by side twin cooler unit has had a slow temp. increase. It's now up to 54 degrees, The...
check the compressor overlaod, it probaly is bad due to the voltage issue with the pover problem it happens frequently with this relay
Apr 21, 2008 | Refrigerators
My 2 year old maytag bottom freezer refrigerator suddenly stopped cooling. the compressor clicks of an on but will not engage. the fan is running
The Overlaod and relay is burnt and has to be replaced .I am a appliance service technician i have seen this lots and if that don,t work check the warranty cause the compressor is bad .
Mar 05, 2008 | Refrigerators
OVERLOAD
I had incountered before VICTOR colored TV.ive found out that the problem was in the switch relay on the power supply area.. My suggestion is to check the relays wich is located at the supply board area resoldered the pin to make sure the pin is in solid contact. or put an AVR back up to your TV. If the problem still occur check the regulator IC or try to change a new IC this might help the problem.
Feb 04, 2007 | JVC (TC30EHGDU6) VHS-C Tape (6-Pack)
Kenmore 53532 / 53534 Side by Side Refrigerator Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
