my monitor works fine except when i plug it into my other computer it goes directly to stand by
Comments:
Dec 24, 2008
- i have two monitors they both work great exept when plugged into said computer. someone had told me to change the resolution that didnt work. I was also told to change the display settings in windows but how can i do that if i cant see a picture also tried the usb ports on one of the monitors and they dont seem to work on any computer.
you might have to change the screen resolution on your "other" computer because it might no be a valid resolution for your monitor. Although you should see the screens when it boots up. You may also want to check if your monitor has an input button and select a different input. Do other monitors work on your "other" computer?
was pink at bottom now a black screen. powers on for a second or two then black screen. green power...
(More)
was pink at bottom now a black screen. powers on for a second or two then black screen. green power light is on.
ok i have an hd pc monitor and when i turn it on all i get a white screen nothing more just white is...
(More)
ok i have an hd pc monitor and when i turn it on all i get a white screen nothing more just white is fixable and can anybody fix this or do i have to take it to a computer repair shop.
How do I reset my Westinghouse L2046NV monitor -- this monitor will turn on and light up and the...
(More)
How do I reset my Westinghouse L2046NV monitor -- this monitor will turn on and light up and the picture will come on but then go off after 1 or 2 seconds -- any ideas ?
tv mode: showing black and white, distorted picture, sometimes will not turn off, sometimes cuts off...
(More)
tv mode: showing black and white, distorted picture, sometimes will not turn off, sometimes cuts off by itself, sometimes can't turn it on by remote or with power button on unit. Sometimes have to move/wiggle power cord to turn on or off. Problem has to be more than the power cord though...I think...because of picture distortion, loss of color and clarity of the picture.
