Question about LaCie Electron III 22" CRT Monitor
How do i get out of hibernate mode and get into standby
  • mentormatt8 May 11, 2010
    Please explain how exactly did you go into hibernate mode. Explain the type of computer, laptop or desktop, and model. Thanks
    President:
  • 1,653 Answers
To get the computer back up again and out of hibernation you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Also the following may be of interest.
You must be logged on as an administrator or member of either the Administrators or Power Users group in order to successfully complete this procedure. If your computer is connected to a network, the forced network policy settings may prevent you from completing this procedure. In this case please consult your Network Administrator.
  1. Click Start, then Control Panel, and then double-click Power Options.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box.
    If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start, and then click Shut Down then select Hibernate.
    If you are using Windows XP Home Edition, or Windows XP Professional with Fast User Switching turned on, the Shut Down menu will present the options to Stand By, Turn Off, or Restart your computer. Hold down the Shift key, and the Stand By button will change to Hibernate.
Posted on Sep 30, 2009
No active standby button, hybernate facility not found.
In the control panel, go to performance and maintenance then click power options. Or, right click the desktop and select the screen saver tab, then click the power button. If the hibernate tab is missing, either your hardware does not support standby/hibernation mode, or it is disabled in the BIOS. If the hibernate tab is available, click Enable hibernation to do you know what.
May 07, 2009 | Computers & Internet
Standby mode is not working..
goto control panel and double click on "power options" under that aplet is the settings for standby and also hibernate.
Dec 07, 2008 | Computers & Internet
Enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
  1. Click the Start button.
  2. Select All Programs > Accessories
  3. Right-click on Command Prompt and select Run as administrator .
  4. At the command prompt enter
    "powercfg -h ON"
  5. Close the command prompt window.
Nov 27, 2008 | Toshiba Satellite L25-S119 Notebook
Doesnot enter standby mode and hibernate mode
hy quick fix go to the web sit and get updates on all mother board soft wair and go 2 my computer propetys and check se if thay are any yellow highlights you will be able 2 solve that way2 good luck plumdj
Oct 08, 2008 | Compaq Presario X1000 Notebook
Computer does not stay in hibernation or standby mode
That happen because on the stand by or hibernate setting the time was setting in 5 minutes.
Go to Control Panel >> Display >> Screen Saver >> Power
And set the time right there as your preferences.
Oct 01, 2008 | Toshiba Satellite A135-S2276 Notebook
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Inactive standby option
>I saved myself from a lot of these problems. I set the power button on the front
>of my computer to put my PC into hibernation.
>This is how you do it:
>1. Go to the Control Panel
>2. Open the Power Options window
>3. If Hibernation isn't on, go to the "Hibernate" tab and turn it on.
>4. Once you have hibernation on, go to the "Advanced" tab.
>5. If your computer supports it, there should be a dropdown menu in the "Power buttons"
>area. From there you can make your computer perform a lot of power management functions
>including Standby and Hibernate.
[Reply or follow-up to this message]
Jul 10, 2008 | Microsoft Windows XP Professional
Stanby mode
Goto control panel, performance and Maintenance, Power options, Power options property, hibernate tab, enable,apply, advanced tab, select how you want to stand-by or hibernate unit, apply.
Mar 17, 2008 | Toshiba Satellite A205-S4617 Notebook
Laptop Freezes
You may have a problem with standby versus hibernation mode. Go into control panel and look for your power options. You need to look for power options for standby etc. Ideally you should not allow your computer to hibernate. Some laptops just wont come out of hibernation mode successfully so preventing it is a good option. Secondly scan your laptop for viruses at the earliest opportunity
Feb 25, 2008 | IBM ThinkPad T42 Notebook
LaCie Electron III 22" CRT Monitor Logo
167 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
