Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
My dishwasher isn't draining and the dishes aren't getting clean. I use liquid dish detergent. Is there a plug or something simple? Thanks
  • 4 Answers
The impeller in the pump may be stuck, I have found that sometimes a small hard piece of material, in my case it was a toothpick gets stuck inside, most are easy to get too, but you do have to pull the dishwasher out from under the counter, unplug the electrical, and when you take off the drain line be sure to have a bucket handy, check tha drain lines, at the disposal as well, most parts are less expensive that you think, I use appliance parts on the web prices are fair, and parts come when expected.
Posted on Dec 23, 2008
ALL LIGHTS ON PANEL ARE FLASHING??
All the lights on my incognito started to flash. This was after the drain/intake light started to flash also. I called Miele and they helped me to reset the lights flashing. They said that when all lights are flashing that this indicates an overheat condition. They asked if my filters were clean and I thought they were. However, my wife had started to use liquid dish washing detergent and the liquid detergent had plugged up the filter screen at the bottom of the dishwasher. I cleaned it good with a scrub brushing and boiling water. This fixed the problem. Bottom line, don't use liquid dish washing detergent in a Miele, only powder.
Apr 08, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
The dishwasher detergent dispenser is gumming up and dishes are not as clean as they use to get.
Purchase a dishwasher cleaner tablet(s)
You may need to remove and back flush the spray arms
Ensure there is nothing blocking the water intake in the bottom
Your issues seems to be low water flow. These are the simple and inexpensive solutions try the first.
Sep 21, 2017 | Kenmore Dishwashers
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
Throughout the whole cleaning cycle the upper sprayers aren't getting much pressure so the dishes dont get washed on the top rack and the detergent isn't getting washed out of the dispencer. What...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jul 07, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
Not cleaning well
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Feb 13, 2011 | Maytag Dishwasher
The dishwashing liquid has gotten thick in my ge dishwasher. The dishes are not getting clean. How do I clean out the dishwashing liquid resevoir?
Try running the hottest, longest programme WITH detergent but WITHOUT dishes. If you usually wash just a few dishes on a short programme, you might find that the machine never gets hot enough to wash away all the detergent residue.
Oct 09, 2010 | GE Dishwashers
Du1100xtpba The top rack of dishes doesn't get cleaned at all. And when we switched from a powder to liquid detergent (to see if it affected anything) the liquid detergent now stays gooped in it's...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Will not clear soap from machine, have to rinse multiple times
are you using regular dish-washing detergent....not liquid dish detergent like dawn....dawn and the like suds up tremendously....regular detergent is manufactured so it will not suds up.
does it drain completely? sometimes a blocked drain will keep enough soapy water in the basin that when the rinse cycle comes on it essentially throws soapy water back on the clean dishes.
hope this helps
Jan 21, 2010 | Haier ESD210 / ESD211 Built-in Dishwasher
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Feb 02, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
134 people viewed this question
Top Hotpoint Dishwashers Experts
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
