Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge freezes up
My fridge freezes just about anything that I put in my fridge. I can't seem to figure out if its worth fixing or just replacing. I have a kenmore fridge its about five years old but even when I adjust the thermostat the result is still the same everything gets super cold and freezes. Please help if you can?
  • Shannon Doyle Dec 23, 2008
    I've tried to turn it down no matter what selection I chose things still get frozen.
    Problem Solver:
  • 8 Answers
Change the theromstat
Posted on Dec 23, 2008
    Problem Solver:
  • 3 Answers
Turn down your fridge
Fisher paykel fridge freezing up
25 years and still have not gotten monies worth?!?!?!?!?
Sep 15, 2017 | Refrigerators
Refrigerator area freezing anything I put in it. have it turned off still running.
Turn the refrigerator off at the power source - leave off for two days - clean the cabinet and then return to normal service - sometimes ice can form on the damper temp control stopping it from closing - this then allows to much cold air from the freezer to enter the fridge freezing everything in it - worth a try as a quick fix
Oct 22, 2013 | Kenmore Refrigerators
Refrigerator freezing food
Fridge thermostat dials are often problematical due to the ones that are numbered 1 to 10, is 1 the warmest or the coldest as the number is lower? Some companies put 'warmer' and 'colder' which avoids confusion. My advice, put it in the middle '5', and leave overnight, check the temperature in the morning with a fridge thermometer. Then change the thermostat dial to 8, and check it the next morning with a thermometer. The next day put it on 1, and leave overnight, check the temperature in the morning. If the thermostat has gone, all three morning temperatures will be the same.
You mention 'or as your website suggests', you know we are not Frigidaire or anything to do with the retailer? We are Fixya, people just like you, helping others. I am a caterer, and just happen to know about fridges. I get them repaired professionally, but always ask for a full explanation of what went wrong. We recently had a sandwich storage fridge that was freezing food, and it was the thermostat that needed replacing.
The things you did, cleaning the coils, will actually make the fridge run colder. The Defrost Thermostat is unlikely to be the problem, as when they don't work, the evaporator, the part that is where the chilled air comes from turns into a block of ice. When that happens, air can't pass through it and the fridge warms considerably.
Due to the damage this freezing is causing with your water and filter, I would suggest you call a service engineer and get it fixed professionally as you will be swapping out parts that are fine. Correct diagnosis is the key, and they will also check the gas pressure at the same time. Consumers can't work with refrigerant gas, it is *******.
Mar 14, 2017 | Frigidaire Refrigerators
The fridge part of my fridge freezer keeps freezing my food. Doesn't matter which setting i put it on.It's suppose to be frost free. Can it be fixed?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Refrigerators
Hi, Our RA21VASS fridge with freezer box seems stuck on the coldest setting after defrosting. Everything in the fridge compartment is frozen and the temp knob appears not to work. Any ideas?
heatman101
Dec 15, 2010 | Samsung Refrigerators
Fridge temperature is too cold, food id freezing. freezer seems fine. even adjusting the fridge temperature up to 1 does not change the temperature. seems to be stuck at 30F.
heatman101
Dec 10, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Maytag fridge MSD2356AE freezes vegetables in the produce crisper.(center crisper). Freezer and fridge settings both at Number 3.
Click Here=> Service Manual MSD2356AE I believe you are having problems with the auto damper 61005993 or 1005661 Auto damper.
If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Feb 25, 2010 | Refrigerators
2004 Samsung RB1955vq fridge cooling/freezing problem
I think that the thermostat breaker in your compressor is getting tired.
Please before spending your money in the PBA clean all the guts of your refrigerator from the dust that accumulates .
Then try it and let's hope it's fixed,
Thank you.
Jul 23, 2009 | Samsung Refrigerators
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
394 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
