Question about Fender Fm25dsp 1x10' Guitar Combo Amplifier
Low volume on acoustic and jazz amp type
Hi, I have a FM25dsp and although it works great on clean and most of the B channel amp types, the acoustic and jazz modes are way less powerful than the others. Even with the volume on 5-6 and gain 5-6 it' still quiet enough for me to play in my bedroom cloase to the amp. For other types I have to bring the volume down to 3 and lower it on the guitar too. Not enought volume on those two amp types for even small gigs outdoor. Any idea ? Also, the manual says each amp type has two modes (acoustic lead, acoustic rythm...) how do you select one or the other ? I tried moving the selector a bit within the space marked 'acoustic' but can't hear any difference.
Thanks
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Ok, so I hope you realize the Fender FM25DSP guitar amplifier is an "entry level" NON-valve amp with a DSP chip that has model shaping tones. I am sorry but this is a toy and Fender did not spend the tens of thousands of US dollars to have built-in tones that truly 'kill". This not digital modelling like Line 6 or Fractal Audio did and so you have a problem from the start. This amp was always intended as an entry level amp for the bedroom only and never to be used on stage.
Jazz and acoustic modes have some similarities requiring mid-range boost and some rounding. Not easy to achieve with a DSP chip that costs about US$10 to manufacture. Sorry, consider using the amp for practice but look at a more serious valve amps for live on stage
Posted on Apr 26, 2017
    President:
  • 1,746 Answers
Hi, Your best bet is the caps. on the inside board. If you replace then you're good to go. Make sure caps are of same value. You can go abit higher on wattage but that's it... Good luck.
Posted on Nov 29, 2017
    New Friend:
  • 13 Answers
I would try another one (same model) if it sounds the same....design flaw...... if it works better.... look for bad solder joints or like the other guy said dirty or broken switches.
Posted on Jun 22, 2017
    Problem Solver:
  • 7 Answers
I agree on the capacitors, as they dry the capacitance drops and the tone rises away from center band, then audio band.
Also check switch contacts (I use Nutrol it's the best) as they can gloss over in areas
Posted on May 03, 2017
    Sergeant:
  • 283 Answers
Should have bought a Marshall and turn it up to 11.
The Amp does not have many watts. Those settings are the DSP or Digital Signal Processing modes, yes it has a computer chip in it :-(
For now just select the setting which you like the best.
I suggest you start looking in the second hand sections for an Amp with more power. You could go Valve (Tube) or Transistor but just get a simple powerful one not a fancy DSP one. For different effects feed the instrument through an effects peddle, there are millions of them to chose from.
Posted on Apr 28, 2017
    New Friend:
  • 4 Answers
Select acoustic lead mode and don't turn your volume done on your guitar for volume acoustic rythm is usually not as loud it will drown out your followers
Posted on Apr 27, 2017
Have to inject signal threw stages in order to isolate falt. It's either in the preamp stages or the out put stage.
Either week tube, or bias component.
Posted on Apr 25, 2017
    New Friend:
Hi, I think that this trouble can have some reasons.
1. Electron tubes seems to be lost emission. Replase it.
2. The capacitors, especially electrolytic, are dried and can have too high capacity resistance (Xc). Replase these components with new ones.
3. Look at the resistors in cathode and anode circuits. If they are darken it can have wrong resistance and the amplifier works in improper mode.
Posted on Apr 22, 2017
5 Suggested Answers
mighty thor
  • 51 Answers
SOURCE: Fender passport model # 250 Used Only Twice!
go back in and find where the electrolitic capacitors connect to the board. They look kind of like a battery. One or both of them have broken loose from the main board, preventing any significant current from going to the output transformer, and causing overload. This is a common problem, and it does not take much rough handling to cause it.
where the break is is at the solder connection. Under a magnifying glass, the break will look like a little circle. Float fresh solder on that or any other large solder joints which may be cracked or broken.
Use standard precautions when working around high voltage.
Posted on Dec 02, 2008
PolyrhythmFX
  • 109 Answers
SOURCE: No volume.
Are the tubes bad? Do they light up? Check the tubes and install replacements if necessary. If it's a preamp tube that went bad, just replace that one tube. If a power tube went bad then replace the set of power tubes. Be sure to get a matched set when replacing power tubes, and to bias them.
Posted on Aug 11, 2009
  • 11 Answers
SOURCE: My Frontman 65R clean channel distorting somewhat
Usualy bad solderr joints on the output pcb
Posted on Dec 07, 2009
  • 94 Answers
SOURCE: volume is very low on
TRY REPLACING VOLUME CONTROL BUTTON.
Posted on Dec 22, 2010
Electric guitar or Acoustic guitar,Which is hard to play?
Electric and acoustic these two types guitar are most useful than any other kind guitar. From my way electric guitar is not so hard to play than acoustic guitar If you can play acoustic guitar then you can play electric guitar too.There is some epic guide of playing electric guitar http://www.musicskanner.com/best-electric-guitars-2016-epic-guide
Oct 30, 2016 | Electric Music
ZENITH MODEL SN 58427 WHAT IS THE VALUE
  • Epiphone Zenith Bass www.epiphone.com/Products/Bass/Zenith.aspx The all new Epiphone Zenith Bass features classic design styling with an elegant profile that pays tribute to great jazz guitars of the past with a gypsy style ...
  • Epiphone Zenith Bass Guitar - Fretless Canada online at ... www.shop.ca > ... > Bass Guitars > Electric Bass Guitars Epiphone Zenith Bass Guitar - Fretless Canada online at SHOP.CA - FSGSEPIEBTRFANB. Quality AssuranceIn spite of all the precautions taken by ...
  • Zenith Acoustic Archtop - The Unofficial Epiphone Wiki epiphonewiki.com/index.php/Zenith_Acoustic_Archtop The Masterbilt Zenith was characterized as a student level instrument. At 13 5/8" wide, this is a very small guitar for an archtop. It has a carved spruce top and ...
  • Epiphone Zenith Bass - Natural - Long & McQuade Musical ... www.long-mcquade.com/.../Bass/Epiphone/Zenith_Bass_-_Natural.htm Since 1873, Epiphone has been designing and making some of the most innovative and classic instruments including the Emperor, Broadway, Casino, Wilshire, Coronet and ...
  • Epiphone Zenith Bass - YouTube www.youtube.com/watch?v=CsuiVj3B9E0
    • BY BASS WHISPERER TV
    • 10 MIN
    • 132K VIEWS
    • ADDED 2011-01-18
    Video embedded · Ed Friedland - The Bass Whisperer demonstrates the Epiphone Zenith Bass for Guitar World Magazine.
  • Epiphone Zenith Acoustic/Electric Bass Translucent Black ... www.amazon.ca/Epiphone-Zenith-Acoustic-Electric-Translucent/dp/... Epiphone Zenith Acoustic/Electric Bass Translucent Black: Amazon.ca: Musical Instruments, Stage & Studio
  • Epiphone Zenith Acoustic/Electric Bass ' Musician's Friend www.musiciansfriend.com > ... > Acoustic Bass > Fretted Acoustic Bass
    • 4/5
    • 1 REVIEW
    Get the guaranteed best price on Fretted Acoustic Bass like the Epiphone Zenith Acoustic/Electric Bass at Musicians Friend. Get a low price and free shipping on ...
  • Feb 05, 2016 | Epiphone Music
    Unresponsive Acoustic channel 2 Marshall as100d ....
    I have same problem. i have this map. please help me to find the problem. if you can point the area in this map that problem is from that.
    Mar 04, 2013 | Marshall Amplification Marshall AS100D 2x8...
    My Marshall AVT150H has low output.
    How do the pots sound? any stactic on the volume pots ? may need replacing or cleaning them if so . I would also consider replacing the tube
    Jan 29, 2013 | Music
    Could you use the Bose 901 series VI for a pa system?
    Actually that's where the bose 800 systems came from.
    Old school jazz guys were using their 900 series turned backwards as a pa
    Mar 31, 2017 | Music
    Low volume from Fishman Loudbox Mini mic input, using brand new XLR cable and dynamic mic. Mic works just fine on instrument input using a Hi-Z cable so problem is not mik
    I have seen defective XLR cables so check it with an ohmmeter. It is possible the mic input preamp has been damaged. If that is the case, the unit will have to be repaired.
    Aug 31, 2011 | Fishman Loudbox Mini Acoustic Amplifier...
    Very low volume from mic input even with Gain and Master turned full on
    You haven't told us what type mic you are using. If you are trying to use a condensr mic with this, you will need a preamp that supplies Phantom power to the mic. You haven't told us what cable you are using. Do check that you aren't using a condenser mic as there will be virtually no volume.
    The reverb channel on my fender twin feeds back
    Not sure of how it is feeding back. Two possibilities... the reverb tank in the cabinet is no longer shock mounted. The other is your guitar can "hear" the speaker... make sure you are away from the amp. With the reverb on, the feedback stability is less than with it off so make sure your guitar is away from the amp. Acoustic guitars are more sensitive to this than solid body ones.
    May 10, 2011 | Fender 65 Twin Reverb 85W 2x12 Tube Guitar...
    How do you switch the behringer 3000 to bridged mode,what settings do you use to get 1200 watts out of it.
    Well... you probably won't like this, but here is some info: In bridged mode, a different Speakon to speaker cable is required from only the B... it is wired differently and you can only use one of the plugs. The speaker or speaker system CANNOT be less than 8 ohms in bridged mode... this precludes using speakers in parallel or multiple speakers that are less than 16 ohm impedance... such speakers are NOT commonly available as most are either 4 or 8 ohm. There is a slide switch for bridged mode on the face of the mixer. Next thing you won't like... The 1200 Watts specification is PEAK power, NOT RMS... You can get 400 watts RMS per side USING 4 ohm speakers. If you use 8 ohm speakers, each of those will get 200 watts. I use this mixer myself and ALSO repair them. The voltage swing at the outputs is about +/-60 volts MAX (peak). This is about 40 volts RMS by the time the circuit LOSSES are taken into account. Across a 4 ohm speaker you get 10 amps times the 40 volts or 400 watts. Across an 8 ohm you get 5 amps or 200 watts. The voltage rails in the switching amp are +/-70 volts DC so these are reasonable values. Bridged mode just uses both sides of the amp driven in opposite directions for higher voltage out BUT you have to use no less than a single 8 ohm speaker so there is NO advantage to bridged mode power wise. IF YOU NEED more power, use extra speakers from an additonal amp driven by the 1/4 TRS mains output jacks OR use additonal POWERED speakers driven from the same jacks. Please read my tip about the hazard regarding the SLEEVE of the cahnnel A cable when using Speakon to 1/4 plug cables being the HOT and the tip being the cold for channel A. Ground the sleeve accidentally and goodbye channel A amp...
    May 10, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
    Fender Fm25dsp 1x10' Guitar Combo Amplifier Logo
    69 people viewed this question
    Top Fender Music Experts
    Michial Gueffroy
    Virgil Watts
    Are you a Fender Music Expert? Answer questions, earn points and help others
