Question about Asko D1706 Built-in Dishwasher
Machine won't shut off when done
When it completes the cycle, it does not shut off.
It's a DW95.2 D1706
thanks
joseph
    Problem Solver:
  • 14 Answers
You didn't describe what the dishwasher is doing. If it is the drain pump running continuously, check this problem/solution.
Posted on Jun 21, 2009
  • mr23 Jul 08, 2009
    I should have added, check the solution I posted on the entry linked above.
    There is a reason that water fills the tray, and there can be other causes than I described in the post. Check the items listed first, and if none of that works, post again and I'll check back later.
Ariston A1637 delay wash and key lock flashing won't complete a cycle
Most likely the problem is a clogged or jammed drain pump impeller. First shut off power to the washer by unplugging it or turning off the breaker. Then remove the screen in the bottom of the washer,clean it out reinstall then run washer
Jul 28, 2013 | Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Asko d1706- drain pump keeps running at the end of the cycle, even in the Off position. Water sometimes remains in the bottom of unit. Any clue
There was a small leak when I re-installed the pump causing water to accumaulate in the base. By reading on your site, I realized that this is normal and expected, for the event that a leak occurs, the pump stays on to purge all possible water.
Thank you
Dec 23, 2009 | Asko D1706 Built-in Dishwasher
Asko D1706.The washing arms have stopped turning.
Can you hear the motor running? If the motor is runningand machine is full of water, but not pumping water around, you have one of the following problems:
-a blockage in the filters or sump preventing enough water getting to motor impellor,
-blocked jets in spray arms themselves,
-or I have had cases where the impellor has broken off the motor, hence motor runs but doesn't pump any water around. Check for blockages first, wouldn't suggest you take motor out and disassemble unless qualified or confident to do so (it's not an easy job if you haven' done it before!!)
Aug 04, 2009 | Dishwashers
Washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Jul 13, 2008 | Washing Machines
ASKO D1706 ... where is the control temp. for element for more dryer ?
you cant ajust the temp its thermostat control,if you want it to dry at end of cycle use rinse aid and open the door at end of cycle to let the steam out.you only have a 55 or 65 wash button on right side next to timer knob.
Feb 03, 2008 | Asko D1706 Built-in Dishwasher
Asko d1706 dish washer
Check if there is water on the bottom pan. Remove the panel down on the backside of the machine and look. If it's water there, wipe it well up with a towel or so.
Jan 27, 2008 | Asko D1706 Built-in Dishwasher
Asko D1706 Built-in Dishwasher Logo
319 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
