Question about Microsoft Windows Server Standard 2003 for PC
Memory problem i have intel 2.66 p4 motherboard. in the starting i got 512mb of ram but now i got 1gb extra memory of ddr2. but when i use 512mb of ram is shows 446mb is accepted by the system and when i use 1gb of ram it still shows 446mb of memory is accepted by the system i am very curious to know that what is the problem of my pc that why it does not accept the 1gb of memory.
    President:
  • 1,179 Answers
It's possible that the new RAM is incompatible with your motherboard. Check board specs to see list of supported RAM & check against what you have. Hope this helps.
Posted on Dec 23, 2008
I NEED RAM FOR MB 210882
This is the specs for the RAM you require.
Memory
The Dell E210882 system board is compatible with PC2-3200 (400MHz) or PC2-4300 (533MHz) DDR2 non-ECC and unbuffered SDRAM. The motherboard has four slots for memory. Compatible capacities include: 128MB, 256MB, 512MB or 1GB. The maximum installable RAM is 4GB.
Google search the Internet for this RAM
Sep 20, 2012 | Intel Motherboard
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
Self having the following configuration on Home desktop PC. INTEL 1.7GHz, P4, D845GBV motheboard with AGP ATI Radeon 9000 graphics card, RAM is 2 x DIMM DDR2 266 Hz, 1 x 1GB + 1 x 512MB total 1.5GB RAM....
Power down and disconnect AC power from your PC. Remove the AGP card and DIMM again and use some "canned air" or dusting spray to get any dust off the contacts on your motherboard and your memory and AGP card. Wiping the AGP card contacts with some isopropyl alcohol (also known as IPA or "rubbing alcohol") and a clean, lint-free cloth can also help. When everything is dry, put your card and memory back in and try powering up again.
Mar 21, 2011 | Intel D845GBV (BOXD845GBVL) Motherboard
Can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets Support for DDR2 533MHz and DDR2 400MHz DIMMs Support for up to 2GB of system memory
hope helpfull
May 29, 2009 | Intel D102GGC2 Motherboard
Computer will not work with extra 1gb ram
It sound like you have incompatible memory. Try taking out the original 256 and test with the 1 gig. Keep in mind some PC requires memory to be paired. If you only have one, 1gig memory chip you might need to get another. I would try removing the 256 first. The specification of the motherboard would also tell you the memory usage.
Let me know if this helps!!
Joe
Mar 25, 2009 | Dell Dimension 1100 PC Desktop
HOW TO FIND RAM CAPACITY OF INTEL D102GGC2
Intel D102GGC2 Motherboard Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.*
Maximum Memory Capacity: 2048MB
* Currently Installed Memory: 512mb Number of Banks: 2
* Dual Channel Support: Yes
* CPU Manufacturer: GenuineIntel
* Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
Your MotherBoard Supports up to 2GB of memory.
You have 512mb, you can add 512mb to the empty slot.
, however,It's a good idea to keep them the same if you can.
You can install memory that is: DDR2 PC2-5300 (PC2-5300 is 667Mhz) you can use 1gb memory in each module for best performance and matching pairs since your motherborad supports dual channel.you can use sound card and SATA hard disk for higher disk support
Mar 15, 2009 | Intel D102GGC2 Motherboard
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
Memory channel mode
Hi shinde32, you should know that dual channel memory should be bought as a pair. Your board has two DIMM slots as you mentioned. The board can handle up to 2GB max memory, as you have mentioned. What you do not seem to know is it is required to use the same amount of memory is each slot. See the bottom of page 55 in your manual. (Do you need the manual)? Download at this link;
http://download.intel.com/support/motherboards/desktop/d102ggc2/sb/d4798502_en.pdf
There is not a bios setting where you can enable or disable memory channels. The bios configures the memory automatically. Intel has a list of memory tested & passed for the D102GGC2 Mb. You can see that list at this next link.
http://www.intel.com/technology/memory/ddr/valid/DDR2_sodimm_results.htm
Bottom line, both DIMM slots should have two 512MB DIMMS or two 1GB DIMM's. (Like this memory);
http://www.bzboyz.com/ProductDetails.asp?ProdID=18112
https://www.thefind.com/computers/info-spd-dual-channel-kit-memory
This is what your search would look like,
"1GB x 2 DDR2 dual channel 533MHz SPD memory".
The Certified "SPD" is important for Intel MB's.
Good luck shinde32!
Need more help, post here.
Thank you for using fixya.
Mike
Jan 15, 2009 | Intel D102GGC2 Motherboard
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Supported ram speed for MSI 945pl-neo f
Your motherboard MSI 945pl-neo support Supports four unbuffered DIMM of 1.8 Volt DDRII SDRAM.( Supports up to 2GB memory size.
• Supports dual channel DDR2 memory architecture.
• Supports DDR2 533/400 memory interface.)
and Supports Socket 775 for Intel® P4 5XX, 6XX, P4EE, Pentium D 8XX and Celeron D processors.• Intel® 945PL/ ICH7 Chipset
for more nformation see details od your motherboard here:
http://global.msi.com.tw/index.php?func=proddesc&prod_no=227&maincat_no=1
Dec 17, 2007 | Intel Motherboard
Microsoft Windows Server Standard 2003 for PC Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
