Question about Frigidaire GLEF396 Electric Kitchen Range
No display - oven/timer/clock inop.
Went to turn oven on and heard a pop pop, then display went out. Can not use the regular or convection in the oven or any of the features on the electronic display panel. The smooth cooktop works fine and the electronic displays for each element work. We have shut off the power for a few hours to see if it would help. No luck.
  • traineng Nov 25, 2007
    I was baking a pizza, heard a pop, saw a small fireball and oven went off and there is no display on my frigidaire electric stove. It is only3 yrs old,
    I have unplug, and reset the breaker
    Top Expert:
  • Frigidaire Master
  • 5,784 Answers
Most likely control / clock has gone bad and needs replacing
Posted on Nov 11, 2017
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: One of my burners is out, and I do not know how to get under the cooktop
You can check the element from the switch on the control panel. Unplug the oven, remove the back and put an ohm meter on r1 and r2 terminals to check resistance. If it shows open then the element is bad. If it shows resistance then replace the switch. To remove the top there should be screws under the front part of the top which you can see when you lower the door then just lift up. You won't be removing just the glass.
Posted on Oct 06, 2007
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
  • 494 Answers
SOURCE: oven went out with a pop
Did someone bump the self-cleaning lock lever? If you have one, make sure it is all the way over to the right. Try resetting the unit by tripping the breaker. Leave it off for 30 secs min and turn it back on. See if that works. If not, let us know and we'll help you further.
Posted on May 18, 2010
I have a Kenmore electric smooth top range that I cannot use the oven on.
it sounds like the clock assy. cooked or there's a shorted wire somewhere,did the bake element crack or short out?this also can take out the clock assy.if the part is 150 dollars that 's not bad,some of them cost 300 or more.good luck with your oven,also you should have an electrician come in and put the stove on it's own electrical line.
Feb 27, 2013 | Kenmore Kitchen Ranges
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Oven went out with a pop
May 18, 2010 | Frigidaire Kitchen Ranges
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
Apr 30, 2009 | GE Profile JTP18 Electric Single Oven
Frigidaire ES400 range - oven will not opperate, range will
Me too. Oven was on, big "pop" and breaker went. After re-setting the breaker (and setting the clock on the range), the stove top works fine, and the controller for the oven seems fine, just that neither the top or bottm elements will heat up in the oven. 240 V is getting to the control module, but it is not sending out any juice to the oven elements.
Any fixes out there?
Mar 30, 2009 | Kitchen Ranges
Kenmore oven stopped working and clock/timer is dead
Try and knock off the oven , leave it for about 10-20 minutes then turn it back on , if its still the same go to the manufacturer or where you bought it... Hope i helped
Dec 30, 2008 | Kitchen Ranges
Neff Oven
It appears that the timer has gone faulty, possibly because of a short in the bulb holder, which probably explains why there is no display and the main oven not working. the top will still work as it is not controlled by the timer.
the solution hear would to be fit a new timer.
Sep 30, 2008 | Neff U1661 Double circotherm super...
Convection oven not working properly???
Model #JMW9527CAQ convection oven has no display visible.Started out very dim and eventually went to no display on the front display .
Aug 17, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Frigidaire GLEF396 Electric Kitchen Range Logo
47 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Sal De
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
