Question about Belkin (F5D7230-4) Router (587009)
Software for the belkin g router will not install on my desktop
I have connected the belkin g router to my desktop, however, when I try to install the software, it gets about 98% done and then prompts me that my computer cannot read the software Can you help?
    Problem Solver:
  • 19 Answers
Reall to be honest with u u dont neet to install the software for the router just open internet explorer and in the address bar type 192.168.2.1 and that will bring up the settings for ur router and u can login and change the settings from that
Posted on Dec 23, 2008
Tip
BELKIN ROUTER MONITOR SOFTWARE
The password has been changed error in Belkin Router occurs because of the Belkin Router Monitor Software installed in your computer <br /><br />Please uninstall it from Your Computer <br /><br />And you can get a better and Stable connection through the Belkin Router <br />
on Dec 19, 2010 | Computers & Internet
Colud yo please help me i have a belkin router installed but i on to change it to a different belkin router every time i tray to install new router ,message comes up can not find new router, do i have to...
1.Yes, you have to save the configuration of the old router to see where you have it .
(print this out so that you understand the configuration.)
2. Uninstall the software for the old Belkin router.
3. Connect the new Belkin to the computer
4.power the computer off / leave off for (2) minutes then turn on.
5. Run new installation software on the new Belkin router.
May 16, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Trying to install Belkin router/modem on PC with XP SP3. Setup assistant reports ''not able to connect to router using any network adaptor in this computer''. Any advice very welcome. Thanks RT
What is pictured on your request, is wireless.. are you on a laptop or a desktop ? Most desktops do not have wireless built in, you would need to buy a CAT/5 network cable to plug in from the PC to your Cable Modem/Router. Then you would use IE to access it, or Belkin's built in installer and configuration software. Some older laptops do not have wireless and/or bluetooth built in. You would then need to buy a PCMCIA card or USB dongle to get back in the grove of the router.
Email me if you need more info.
Toby White-Beebe
Dell Certified Lead Systems Expert
Aug 28, 2009 | Belkin (F5D7230-4) Router (587009)
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
Jul 15, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Driver software for Belkin F5D6230-3
You shouldn't need drivers for this. All you should have to do is plug it in to wall to power it, connect your cable from your isp
What Operating System are you using?
Here is a link to the Belkin site for the user guide etc.
The flash tutorial is pretty good.
Jan 29, 2009 | Belkin (F5D6230-3) Wireless Router
Belkin Wireless G Router causes loss of internet connection
Does your router have one LED lamp for each "wired" port?
If so, does unplugging the Ethernet-cable (the one that connects to your desktop PC) cause the lamp to go off?
Does reconnecting that cable cause the lamp to go on?
Also, on your desktop computer, there could be a lamp right beside where the Ethernet-cable connects into your computer.
Again, disconnect the cable, and reconnect the cable, to see if that lamp goes off/on.
Have you tried a different cable?
Do *NOT* connect your desktop computer to the 'WAN' port on the router -- connect it to any of the "LAN" ports.
Dec 22, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
Hi, I have a desktop and a wireless router. The desktop was connected to the internet via a Belkin USB wireless adaptor but it has suddenly stopped and does not pick up any signal. I have uninstalled and...
Belkin products are notorious for breaking down at a high rate. If you wanted to rule out your computer as the culprit, you could install the belking adapter on your laptop (disable the built-in one) and see if it still works. I would also suggest going here:
http://www.belkin.com/support/
and typing in your product model # and downloading the latest firmware/software for it. As always, restart your computer.
Jun 10, 2008 | Belkin Computers & Internet
Belkin (F5D7230-4) Router (587009) Logo
185 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
