Question about Indesit W 123 Front Load Washer
My Indesit Washing machine doesn't seem to start?
Recently the machine has been working fine but on day one of the pipes leaked and maybe spilt some water on the top of the machine. We quickly turned everything off but just before, the machine cycle knob turned 360degrees before stopping and afterwards producing a burnt smell. We checked if any water had gone inside, but we found it completely dry. Now the machine won?t start. When we push the on switch we can hear a clicking noise and the light vaguely comes on then off but it just won?t start. Could anyone please help? Thank you
    President:
  • 1,294 Answers
Most likely water has short-circuited your controls; you need a specialist here.
Posted on Apr 11, 2007
SOURCE:
How to open the top of Indesit wil 106 washing machine.\?
unplug the machine and remove the two screws at the rear of the top panel take it off check there are no leaks in the pipe works eric
Jan 17, 2018 | Indesit Washing Machines
Indesit widl126
It sounds like the seal is worn out around the hose possibly or it is just loose and needs tightening. Depending on how old your machine is, the hoses get dried and cracked over time as do the seals.
Mar 10, 2014 | Washing Machines
Indesit iwme12 fills with clean water when not running
sounds like a faulty valve. it maybe weeping, leaking water in.
Jun 20, 2013 | Washing Machines
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Water leaks from underneath Indesit WG1130d washing machine.
I had a problem like this and it turned out to be the hose that carried the water out to the drain was overflowing the drain pipe.
Make sure the P trap in your drain line is open and clear. A plumbers snake, draino, or a high pressure nozzle on your garden hose might help to clear it.
Oct 04, 2017 | Indesit W 123 Front Load Washer
When water goes in,then it starts leaking from underneath-have checked for blockages.Spin seems slow and not washing clothes?? Then dial seems to go around sometimes on its own???Help!
has the bearings been replaced recently or may need replacing it has been known that should a bearing get a bit sloppy then the drum rubs on the outer caseing wares a hole in it the outher casing is plastic
Jan 16, 2010 | Indesit W 123 Front Load Washer
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Indesit w123 washing machine
Suggestion: The pipe behind your machine has to have a certain height (the machine drain pipe); it does not go directly into the drain at floor level. Check this out.
May 22, 2007 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
303 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
