Question about RCA F31672ET TV
RCA MODEL F31672ET
WHAT STARTED OUT TO BE A POWER PROBLEM, WITH I BELIEVE A RELAY, IS TURNING INTO A NIGHTMARE. NOW THE POWER IS ON, BUT I HAVE NO SOUND AND THERE IS VERTICAL ROLE THAT I CAN'T FIGURE OUT. SOMEONE OUT THERE PLEASE HEEEELP!
THANK YOU.
  • RCA Master
  • 1,241 Answers
You have a Tuner on Board that needs reworked. You must remove the bottom shield and resolder about 20 points. As for the sound problem you may by now have a bad eeprom [location U3201]. We may be out of Horizontal Frequency as well. First fix the tuner then replace the eeprom.[Iwould install an eight pin IC socket upon removal of eeprom, then you can insert or remove the new eeprom anytime after this]. And also check capacitors C4404 200V at 2.2MF, C4105 200V 10MF Will be bad in this case, C4127 and C4709 these may be weak. This shuld repair your TV. PS the eeprom part# is 223957. Before you change the eeprom see if you can get a good picture after resoldering the Tuner. This is delicate work so be careful or you will destroy the TV. If you do have a good video and no sound, clip R1915, this will defeat the mute,but sound will return. Just so you know repairing this TV is quite complicated good luck.
Posted on Apr 29, 2010
Wiring schematic for a RCA model F31672ET television
Send your email address to me and get the schematic by return mail.
Apr 17, 2012 | RCA Televison & Video
Can i use my RCA F31672ET TV as projecter for my computer? I cant find any HDMI port.
Not possible as model listed is composite video only with two additional inputs for audio--no way I know you could do this.
Mar 20, 2012 | RCA F31672ET TV
I need to get the remote control for my tv. rca model F31672ET
An exact replacement remote may not be available. However, a substitute remote with the functions of the original is here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12930827449040&smodel=F31672ET&brand_pn=RCA_F31672ET . Most universal remotes programmed 6 months after the TV was released should have a code for this RCA TV. However, it might take a bit of searching to find the right code. You might not get all of the features from the original remote with the cheapest of the universal remotes (pip, input changes, etc). The universal remotes that can be programmed via a USB connection with a computer will do all of the features but are much more expensive.
I hope this helps.
Dec 23, 2010 | RCA F31672ET TV
Tv Doesn't have power
This TV is component level repair - there are no boards available. The is a company that remanufacturers whole boards - you can see if they do your model. PTS corp. 800-844-7871
Jun 11, 2010 | RCA F31672ET TV
I have a rca tv model F31672ET. I do not have the
Check with the channel 00 good luck
Jun 05, 2009 | RCA F31672ET TV
RCA F31672et is not turning on sometimes/now green on screen
Its your Tuner. There is a chance that since this has been going on so long that your IC that controls the Tuner could be shot. For a Geek this could be a semi easy fix. The parts for the most part are cheap. The problem is identifying what is what via the net. There is a chance that the IC isn't shot yet but you need to get out your solder gun and get to work by re-soldering your connections
Apr 23, 2009 | RCA F31672ET TV
No sound
Clip R1915 and the sound will return. But you still have a Tuner to rework. See my solution with the power problem. just before this answer!
Oct 14, 2008 | RCA F31672ET TV
RCA Model F31665 will not stay on
as allthings you need to pay money or there is no help.do you think kindness is for free.
Sep 24, 2007 | RCA F31672ET TV
RCA F31672ET No Power only a whining noise when plugged in Please help
Most likely you have a bad flyback transformer and shorted horizontal output transistor. The whistling sound that you hear is the power supply telling you that it has a short in one of the circuits it powers. Most likely the circuit mentioned above. Stargazer
Mar 06, 2007 | RCA F31672ET TV
Televison & Video Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
