Question about Samsung PCN5425R 54" Rear Projection Television
Convergence: concave picture with double image
My pcn5425r tv has developed a problem with the picture being concave on the screen and double like image to it. I noticed someone else listing the same problem with no answers listed, hoped maybe someone had figured out a possible solution? Thanks
  • 1 more comment
  • Don Davidson Apr 10, 2007
    Thank You for the the help, this helps me greatly after talking with another tech online yesterday. Now have two great tech's giving me same resolution to my problem, all I need to resolve is to verify part numbers, and order service manual for adjustment purpose after changing new board when I get it. Thanks both very much both of you saved me at least two hundred dollars on easy change out. May need ya'll again on realignment.
  • Don Davidson Apr 11, 2007
    Thanks for the recommendation, I ordered the board today and decided to wait and see how much extra adjustment might be needed before ordering the service manual. I really appreciate your help and advice.
  • kevlarnovack Nov 05, 2007
    I have recently experienced the same problem as stated in this post. I replaced the convergence board with the replacement version, but it fits exactly. The picture is still double-vision, but the concave problem went away. Now, I also get the message "NO SENSOR DATA". I've had the TV unplugged for over a day. Everywhere I read that I need a service manual. Where can I get one of these? Are there any quick hints that will help?
    Thanks!
    President:
  • 1,284 Answers
An easy replacement on the Samsubgs is to replace the convergence board. If you are doing this yourself it is just a plug in board. Here is a link for the part number and how to purchase it. http://www.partstore.com/Part/Samsung/Samsung/PCN5425/Samsung/Samsung/BP9400383A/New.aspx
Posted on Apr 10, 2007
  • Don
    Don Apr 10, 2007
    You probably won't need to do anymore alignment then the customer convergence alignment. I would hold off on the service manual.
Picture appears concave and doubled
Most likely scenario is that the auto convergence option has disappeared which will cause the set to have an arced picture with double images. You can get the RCA repair kit called ITC222 & ITC222A convergence option missing repair kit from www.tvrepairworld.com which has the replacement parts and the CD with instructions.
Jul 31, 2010 | RCA HD52W56 52" Rear Projection HDTV
The screen is concave and has double pictures
Convergence is dead.Must know how to solders?Must replaced convergence ICS and all it resistors.Tries waebsites Tv repair World.com,Tvrepairkits.com for the convergence kit.
Jan 16, 2010 | Televison & Video
Problem with my Samsung PCN5425R 54 in. projection. I am seeing double and pictured is bowed and I see red and green colors on the screen. Is this the convergence board. Is this difficult to fix? I am not...
Your convergence ic’s have failed, this is a common problem with most all projection tv’s, the repair is involved. I suggest in your case calling a local repair shop.
Sep 01, 2009 | Samsung PCN5425R 54" Rear Projection...
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Seeing double on my samsung rear pro
The convergence IC's are definitely bad. They are not a plug-in device, they solder in so this is a big job.
Mar 30, 2009 | Samsung PCN5425R 54" Rear Projection...
By the picture that you have supplied with the question you have a rear projection tv. The problem you are describing sounds like you have had the convergence module in your tv fail. Depending on the age and make of the tv, the repair costs ( if out of warranty ) can be prohibitive. The convergence module on rear projection tv's not only is in charge of bringing the 3 different color images together into a watchable picture but also handles the east west correction ( concave / convex aspect to the picture or lack there of ).
Jul 02, 2008 | RCA R52WH73 Projection Television
Tv problem samsung PCN5425R 54 in.
Very easy repair....Just replace the convergence amp board part# BP95-00142E (about $80) It includes both convergence IC's and associated components (Five connectors,one screw,easy access)no soldering...
Sep 20, 2007 | Samsung PCN5425R 54" Rear Projection...
Concave picture with rainbow effect at the edges
Hello, Check and replace IC1606 (P/N: 875292571) and IC1608 (P/N: 875982987). Best regards, Arpi http://www.partstore.com/sl/2/418644-ic-cxp86448635q-875292571.html
Apr 23, 2007 | Sony KP-57HW40 57" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Auto Convergence not working
I'm assuming you were having picture quality problems prior to pressing the auto convergence button. If not then there could be a problem in that circuit. More likely I believe is a problem on the convergence board assembly or in the pincushion circuits. Also, check your owners manual to see if there is a manual convergence adjustment you can do.
Jan 27, 2007 | Zenith R49W36 49" Rear Projection HDTV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
172 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
