Question about Gateway MT3705 Notebook
What do you think is wrong with my laptop?
I just got off the airplane and came home and my laptop will not even come on or register the battery charging . My gateway laptop is only 2 weeks old.
    Scholar:
  • 86 Answers
Did you keep your laptop with you the entire time? Remove battery and plug in the power and see if it will come on.. If that doesn't work remove the battery for 15-20 minutes and then see put it back in plug it up and see if it works this time. If not the Airport might have been too rough with your baby...
Posted on Dec 23, 2008
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 | Cell Phones
I have an acer aspire 5736z. The charger itself is fine- been checked on another laptop but my laptop won't even register that the charger is connected on the little display lights. Same charger as came...
If you have to ask, i think it will not be easy. And be aware there could me more wrong then just the connector. there is a (flat?) cable, and a battery and some logic. If you don't have skills to repair electronic equipment, please don't start. You could damage more then you like. Ask a skilled person to ell you.
Jun 22, 2014 | Computers & Internet
My samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Apr 05, 2012 | Samsung R480 Notebook
I put my mytouch 4g on airplane mode for an international flight. after I took it off airplane mode, i don't get ANY signal. I've turned the phone off, taken the battery out, everything. Whenever i go into...
If you're out of your home cellular network (T-Mobile) and you're in another country, maybe you don't have the roaming service active in your number profile, then you can have an error message, but if you have roaming activated, sometimes it's necessary to manually register into one of the available networks where you are.
Mar 15, 2011 | T-Mobile My Touch Cell Phone
Airplane Mode
My phone once resisted the bottom "unlock" slider for about 10 seconds. I think I just waited and tried again and it worked. If that doesn't work for you, run the battery down all the way.
Besides, once the iPhone boots up, it should go straight to the home screen, right? Not to the "locked" screen with the slider and wallpaper.
Jan 07, 2008 | Apple iPhone Smartphone
Gateway MT3705 Notebook Logo
135 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
