Question about Sharper Image SA260 CD Shelf System
Sharper Image SA260 Stereo Shelf System
I am attempting to connect an external audio unit to the SA260 through the front AUX RCA jacks of the system. I select "line" function on the top of the unit. Result - nothing. Since the unit has a single set of inputs and according to the instructions, I should be able to switch the AUX mode from out to in. This should be a no brainer. Mo luck thus far. Does anyone know how to switch the AUX line to "in" in order to recieve a signal? Thank you
  • Kid611 Nov 26, 2007
    I'm having the same problem and have just sent an email to Sharper Image's customer care to see if they can resolve. I'll let you know what I hear.
Open the stereo doors and switch the line button on the bottom right from out to in
Posted on Aug 01, 2008
Where is the aux jack for the RCA RS 2620 bookshelf stereo?
The Aux audio L/R input jacks are below the On/Off button on the left side of the front of the stereo's main unit. The headphone jack is just below the input jacks. You will probably need an adapter to split the stereo output from the Blackberry (probably a 3.5 mm stereo jack) to the L/R jacks.
Radio Shack has the manual for the RCA RS2620 here: http://support.radioshack.com/support_audio/doc72/72312.pdf .
I hope this helps.
Feb 04, 2012 | RCA RS2620 80-Watt 5-Disc Shelf System...
I want to plug stereo cables with the red and white ends into my LG FB163 mini shelf stereo, so that I can use my Airport Express to stream music from iTunes, but I don't know where to plug the red and...
there should be an aux/analog in. if the analog/aux in does not use red and white rca jacks, then it must be a single 1/8th inch jack input, like a headphone jack, and you will have to get an rca to 1/8 inch "Y" adapter
Nov 06, 2010 | LG FB163 DVD/DivX USB Micro system Shelf...
I would like to plug in the sound of my television set to the panasonic SC-PM08. I tryed to do that by plugging in the tulip plugs in the "aux" connections, but no sound comes out. what could be the...
You mention "tulip plugs"! are you referring to your RCA jacks in the back of your unit? That is what the 7 inputs are to the right of your speaker connections.
When you hook your "stereo TV" to your external sound unit
you need to run your cables to your aux input from your audio out jacks on the back of the TV. Once this is done you need to configure your TV and your sound unit to work with each other. You need to go into your TV settings and tell it where to send the audio to. If you hooked into the front audio output then you need to pick that selection. If you hooked into the back audio out you need to pick that selection. Once you have completed that you need to tell your sound unit where to pick the sound up at. If you plugged into the aux then put your sound unit on aux. If you have more than 1 aux pay attention to what aux your TV is coming in on and set your sound unit accordingly.
Mar 09, 2010 | Panasonic SC-PM08 Shelf System
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
Is there a way to hook up an ipod to this stereo so it will play the ipod music through the stereo? Can I purchase a docking station that will hook up to this stereo?
Just get an adapter for to connect from the Ipod headphone jack to a standard RCA cable pair. Jack into AUX or whatever available input you have.
Dec 05, 2009 | RCA RS2652 Shelf System
Need power cords
look at thrift store, most cords should work, with little or no modifacation.
Oct 06, 2009 | Sharper Image SA260 CD Shelf System
Sharper Image SA260
activate the reset button on the back of the unit (you'll need something like a toothpick or a needle to do this) this should do the trick (it did for me) hope this helps
Jun 16, 2008 | Sharper Image SA260 CD Shelf System
Surround Sound using the video feature
You will not get 'surround sound' from this set only stereo sound. The Video/Aux jack at the back of the unit is an input terminal. You can connect the audio part of your TV(if it has a Line Out jack), dvd player or video game console to this input to get the sound through the stereo system. Use a male-to-male RCA cable to make the connection, they are color coded (Red and White). Press the "Video/Aux"  button to select the input terminal.
Nov 04, 2007 | Sharp CDBA3100 Remanufactured Mini-System...
Clock adjustment
Turn system off. On remote press the MEM/PGM button. The hour will blink. Use the tuning buttons on either the remote or system to advance or reverse the hour. Press the MEM/PGM button again to make minutes start to blink. Again, use tuning buttons to advance or reverse as needed. Press PGM/MEM button one last time to finish the process.
Really, could this be any less intuitive?
Hope this helps people out. :-)
Sep 01, 2007 | Sharper Image SA260 CD Shelf System
Sharper Image SA260 CD Shelf System Logo
660 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
woodzowl307
Tom Chichester
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
