Question about Gateway 504GR PC Desktop
Noisy-part 2 I wrote a little while ago and you guys were kind enough to answer. I am trying to open the tower to clean the dust. I looked on the back and there are 2 big screws that come off by hand---but then the side does not come off. There are other screws that are smaller and will need a screwdriver. so....I'm not sure which side comes off (opposite the motherboard except I'm afraid I don't know what that is) and which screws . I am hesitate to start taking off screws. any other ideas?
  • Anonymous Jan 07, 2009
    I am using my computer in a safe mode with networking. Since I switched to safe mode my engine sounds like a jet taking off and never stops running at such a high speed. I did check the back and the fan is full of dust. If I go out of safe mode I end up with 35 trojans at my door. So what do I do?
  • 15,935 Answers
Look at the rear of the pc. the motherboard will be on the side all the connectors are off centered. so if all the connections are on the left, open the right side. if the fingerscrews are off.... slide the side toward the rear of the PC and it will let go. There are little tabs holding it in place.
Posted on Dec 23, 2008
Noisy cooling fan
Hello! You may have a cheap and loud fan. If it was not noisy earlier, you may have to clean it. It is not difficult at all. First, buy the cheapest clean compressed air spray on the market (approx $5.00-8.00). You just unscrew the computer chassis, and look for all fans. IMPORTANT: before you open the chassis, UNPLUG the PC. Now, if you don't want to "un-cable" the whole PC, just open the windows in your room. Spray the air onto the fan and below the fan where the heatsink is. A LOT of dust will fly blow off, you'll see.
Where are fans in your PC?
1.) On the CPU heatsink.
2.) one or two in the Power Supply Unit (where all the cables are coming out, kind of a metal box - just spray into it too.
3. Graphic card
4. Chassis fan(s)
Clean them all with the airflow from the compressed clean air can.
In addition I'd recommend you clean the other parts and boards, so you have a nice clean PC.
You may watch the attached video too, if you want to go deeper into it, but in my case it always helps. Note, that if your PC is really full of dust, you'll need the whole can to clean it. But it's worth it.
Hope I could help. If you have questions just leave a testimonial and I'll come back to you and help you with pleasure!
Jan 04, 2014 | ASUS Computers & Internet
My PC restarts after about 2 hours, Why is it doing that?
Maybe it's a temperature problem. Disconnect the tower from all the connections. Open up the tower and use a vacuum and a soft brush (or even better an air blower or clean air under pressure) to clean up the dust from the inside. Take special care at the any coolers on the motherboard and VGA and at the power supply. After that leave the tower for some minutes to rest (especially if you used air under pressure). Connect the tower again and start up the pc. Check for some minutes that the blowers are working correctly (maybe someone is not working and needs replace). If everything is all right close the cover and check the results.
Of course this is not the only cause for these kind of problems, but we have to start from somewhere.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Oct 22, 2010 | Computers & Internet
I am getting little brown spots on my white clothing. Bleach seems to take them out. It just started happening.
sounds like a rear drum shaft seal may be leaking and getting either rust or brown grease spots on your clothes.If this the case,you should be able to see signs of water leakagein the back of the unit.Take the rear cover off and look in the area behind the large drum pulley.This problem also usually results in noisy operation eventually.The water would be getting into the tub bearing behind the seal.
Aug 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
NOISY FAN ADVENT T9302 COMPUTER ON ALL THE TIME
Ok, for your first issue, remove the side from the case, and have some compressed air at the ready. from a distance of 6-12 inches direct the air into the heatsink and blow out as much dust as possible. do this also for the power supply and an other fans and areas where dust is caked on. Secondly, this issue can also be attributed to a bad stick of RAM.
Apr 05, 2010 | Computers & Internet
Preasrio CPU fan is noisy and goes on A LOT
It's not your ram. What it means is that the system probably has inhaled too much household dust and is having trouble breathing. That is not a joke. The system has fans, and the fans are responsible for moving fresh air and unfortunately dust into the enclosure, and exhausting the heat. If the air is choked off, the heat builds up. If it gets to the point that the fan runs constant, the processor will slow down to compensate and avoid further overheating. That will make the computer slow. If you feel handy, you might get yourself one of those cans of compressed inert gas they sell at the major chains, unplug the computer and take it outdoors, remove the cover, and commence to cloudmaking. If you don't feel like that is for you, you can take it to a servicer, but it's gonna cost you a little more.
Jun 14, 2009 | HP Compaq Presario SR2011WM PC Desktop
Dell Precision 670 Workstation REALLY LOUD and NOISY
It could be due to a failture of either the SMPS fan (Power Supply), the system cooling fan or the Videocard fan... Now checking the power Supply fan issue is easy... Take a toothpick {wooden} n insert it between the fan fins at the back of your tower... This is the fan that is visible from the back of your tower... Now if the noise stops then it is the SMPS fan issue
If it still persists then do the same procedure with the CPU fan located on the inside of the tower.. this is a bit tricky but you seem tech saavy enough to do so but anyways this is the link for a step by step procedure of getting inside your desktop
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/index.htm
The third case is the Graphics Card... now there is no way we can say this with certainty but you can do this... remove all connections from the back of the tower.. remove the graphics card, connect just the power chord n start back up... if the noise is gone then the Video Card is the culprit.. REMEMBER TO REMOVE POWER CHORD ALL TIMES YOU OPEN THE TOWER N BE VERY VERY CAREFUL N FOLLOW THE MANUAL  :-)
Feb 12, 2009 | Dell Precision Workstation 670 PC Desktop
Noisy
there are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Dec 22, 2008 | Gateway 504GR PC Desktop
JVC HD-56G886 56INCH REAR PROJECTION TV
I fixed it!!!! If you can open one of the sides (on the JVC there is a little door with a screw), then you can clean the projector lense in the middle on the bottom. It kind of looks like a big light bulb. It seems there is just dust on the glass that is projected onto the screen. We had a big gray spot and cleaned it with a damp glass cloth and Ouila! It disappeared. I scored MAJOR brownie points with my husband for this one! He wanted to replace the TV!
Sep 25, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Replacing the hardrive
i do not have the same model as you but generally all covers come off in a similar way. first have a look round the tower and you should see screws mainly at the back, have a good look at the screws because some hold components to the cover inside. you need to look for screws that are right on the edge of one side, generally larger than any other, undo them,then check the bottom of the tower on the same side as these ecrews, remove them, then the side that had the screws should slide towards the back, it may seem a little stiff, but should slide backwards a few centimetres and then fall,off loosely. hope this helps
Sep 06, 2008 | Sony VAIO Digital Studio PCV-RX860...
After restoring a Presario 1700, a blue screen is displayed and the error says something about dumping physical memory. I have used the quick restore several times with the same result. Answers?
this could be a hardware problem. Open your tower,
1). check the inside of your tower for dirt and dust, give it a clean.
2). check your ram memory. be sure they're pushed in good. you may have a bad memory stick and need a new one. maby find a friend a use thiers to see for sure.
3). some times compatability problems can be conflicts enough to cause problems. check your hardware for compatability confilcts.
* but i'd check the memory first *
Aug 11, 2008 | Compaq Computers & Internet
Gateway 504GR PC Desktop Logo
43 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
