Question about Goodman GDS80904BNA Open Flame Heater
Goodman gmp050-03 heater
Turns on, fires up blower fan kicks on...two minutes later gas turns off but unit keeps running, red light indicates stuck gas valve...now what
  • 56 Answers
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Posted on Feb 13, 2009
Blower fan not working
check for proper voltage from the transformer to the blower to see if blower is recieving voltage. check continuity on motor windings.....open loop indicates windings are shot
Jun 11, 2013 | Goodman GMS90703BXA Heater
My goodman furnacs says my limit switch is bad blower works but does not ignite .....? its modle gmt070-3 and where is it located
There are several limit switches in the unit there in various places in burner compartment. One on blower housing . One thing that I would try is replaceing your filter and turn the power off to the furnace and try starting the system after power is D/C for 5 minutes.
May 02, 2011 | Goodman GMS90703BXA Heater
Goodman gmp0503 unit has status light blinking slowly all the time. The indoor blower wont even come on when you switch from auto to fan on thermastat. The status light says for one blink to check gas...
Take a jumper wire and jump out the R and W terminals on the furnace. The heat should come on. If it does not, you have a bad board. A steady blink indicates no call for heat. You may have either a broken thermostat wire or a bad thermostat if unit fires when you jump it.
Mar 20, 2011 | Goodman Heating & Cooling
I have a goodman gpmn furnace. The ignitor lights, and then the flames turn on, then the blower kicks on, and about 30 seconds later the flames turn off, and the blower continues to blow air. We have tried...
Hello, looks like you limit switch keeps opening because your furnace is overheating, Check your air filter and blower wheel to make sure it is not dirty and make sure you blower motor is moving at the proper speeed. Usually when air flow is cutoff the limit switch will open.
Feb 15, 2011 | Goodman GMS90703BXA Heater
We have a goodman split unit, It was below freezing the other morning and the unit had a squeaking sound when it started up. Now it has warmed back up, the unit is sounding as if it's trying to kick off...
The symptoms seem to be related to the main blower motor and/or it's capacitor. Turn the system off for a couple of minutes and then turn just the fan on while the thermostats heat setting is in the off position. If the lights still dim then replace the motor and capacitor. The clicking noise is the fan relay.
Dec 17, 2010 | Goodman GMS807034ANA Heater
Goodman GMP100-4
my guess would be a flame/temperature sensor
Feb 12, 2009 | Goodman GMS90703BXA Heater
Forced air fan
You might have a sensor issue where it thinks it's too hot and kicks on the gas exhaust fan.
Oct 01, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
154 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
vance jones
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
