Question about Haier Energy Star ESA3183 Air Conditioner
Carrier heat pump: aux heat does not seem to work
The "Aux HT" indicator went on, however the room temp will not go up.
I change the mode to "EHEAT", the fan on the outside unit stopped, "Aux HT" indicator is still on, however the room temp still not goes up. The air comes out of the vent is warm but not hot...
Any hint what's going on? Thanks a lot!
  • 1 more comment
  • yeqwang Dec 23, 2008
    thanks. It has been very cold these days....I did not have this problem during the last several years when it was this cold though. .
    How many square foot are you trying to heat?
    >> about 1700
    What is the outside temp?
    >> 10s-20s
    What is the inside temp?
    >> it can not go above 61~ 62 no matter how high I set.
    What size unit (BTU output) do you have?
    >> I do not know... 36000... make sense? a number I figured from the model number...
    some more info..
    When in "Heat" mode and "Aux HT" indicator is on, the fan in outdoor unit won't stop..
    When set to "EHEAT" mode, the fan does turn off.....
    Thanks!
    yes, I have one meter. can you tell me how to allocate them and do the measurement? I have some knowledge of electricy stuff....
    Thanks for the direction!! This helps a lot!
    When I set it to the EHEAT mode and put my hand on the vent goes out, I can feel one side is warmer than the other side... There a pair of coils there...
    I checked the coil. It has reading on both ones.
    I will check the relay and the protection switch...
    Please let me know if you have any other thought!!
  • 334 Answers
The unit is probably to small for theare you are trying to heat.
When the Aux HT light came on that meant the heat pump could not keep up with the demand for heat. (Probably due to extreme cold, or undersized unit.)
If yu have heat, then at least one heat strip is operating. If you have multiple heatstrips, one or more could be malfuncioning.
Or it could simpy be to cold/to small fr your area and not able to keep up.
Posted on Dec 23, 2008
  • 1 more comment
  • Danny Clark
    Danny Clark Dec 23, 2008
    It sounds like you may have lost one of your heat strips.
    This could be due to a bad heat sequencer (relay) or a bad strip itself.
    If you have a volt/ohm meter I can help you diagnose which one it is.
    Do you have a meter, and would you like to procede in that manner? If not, The next step would be to replace the relay and strip, or call a tachnician.
  • Danny Clark
    OK, Turn off the main power to the airhandler. Take the panel off so you can access the heat strips.
    You will need to locate the strips, (probably two, maybe hree strips, only the terminals will be exposed.)
    disconnect the two wires on each strip. (one wire on each terminal.) Check for continuity accross the strip. If you have continuity, the strip is fine.
    To check the heat sequencer/realy, you will need to turn power back on (Be sure to reconnect the strips just as they were connected before) and check for amperage going to the strips.
    (Make sure the t-stat is calling for heat, set on e-heat)
    Each strip should have 15 to 25 amps.
    Whichever strip does not have anyamp draw, thats the problem strip. Now if it has continuity, you know it must be the relay to that specific strip.
    The relays are usually sigle or double stack.
    The 24volt coil is at the bottom with terminals on each side.
    The realy sends power accross rom the line side to the power side to power up the strip.
    If you have 24V across the coil, and you do not have 240V on the line side of the realay, the relay is bad.
  • Danny Clark
    how many amps did you have on each coil?
2 Suggested Answers
  • 92 Answers
SOURCE: Carrier heat pump: aux heat does not seem to work
you have a heat pump which removes heat from outside air when it is too cold out below 30* the unit can no longer produce heat and electric strip heaters kick in
Posted on Feb 06, 2009
What does it mean when the aux is flashing on my thermostat?
I assume that you have a heat pump system. If this is the case, the outside temperature is probably lower than the heat pump is sized for and it is using the auxiliary heating system to keep up. The auxiliary heating system usually is an electric coil in the heat pump unit which supplements the heat being produced by the heat pump. This is normal operations and does not indicate a problem with the heat pump, it is just really cold outside. If it is not colder than usual outside, there may be a problem with the heat pump and you should call a heating contractor to check it out.
Jan 10, 2015 | Emerson 1F89EZ-0251 Blue 2" Thermostat,...
Eheat will not come on
When resetting anything electronic, leave switched off for about 15 mins. The electronic boards store the memory of any failure or problem and switching off for only a few seconds or minutes will not reset the board. Turn off at the mains supply not the wall control.
Nov 25, 2013 | Heating & Cooling
Aux keeps coming on on regular heat is there something wrong with heat
See if it happens only when your temperature of the room is more than 3 degrees of your setpoint temperature. Since you have a heat pump, the auxiliary (electric heat strips) is use for backup of the heat pump when it can't keep up. The heat pump will run by itself if it can maintain temperature within a couple degrees. If it is too cold outside to handle the load or you set the temperature more than 2 degrees past room temperature, the auxiliary will turn on. The thermostat has a memory of how long it takes to reach desired temperature. If it goes into auxiliary mode trying to satisfy setpoint during the last call for heat, it will start the next call for heat in both aux & heat pump mode until the thermostats algorithm (timed program) allows only the heat pump to run. Not sure if you have an air to air, or geothermal heat pump. The outside air temperature will affect only the air to air system ie. when the temps drop outside, the heat coming out of your vents will be cooler...the air to air systems drops efficiency when the outdoor air drops.
Nov 08, 2013 | Honeywell TH3210D1004 PRO 3000...
Buzzing sound when aux heat comes on
Sounds like it could be a effiency function to warn you that the heat elements are on. Check your thermostat manual and see if you can turn this feature off. If this is not a feature then the thermostat may be wired wrong or something in the circuit may be trying to short out.
Jan 04, 2010 | Honeywell Electronic Programmable...
What does aux mean on a honeywell Thermostat? the heat doesn't seem to be working but warm air is comming from the vents and the heat pump fan is spinning just not enough to match the temp. it's set too....
The aux switch is for electric heat banks installed in the air handler. Depending on the outside temp. it may not be efficient to run in heat pump mode but in aux. or emergency would run the electric heat in the air handler.
Dec 11, 2009 | Goodman Heating & Cooling
What is best and the difference, HEAT, AUX HEAT, OR EHEAT?
Heat is best.
aux heat comes on as needed to assist heat.
e haeat is used if heat should fail.
it is for emergency heating only.
Mar 15, 2009 | Heating & Cooling
Feb 06, 2009 | Heating & Cooling
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in...
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Jan 25, 2009 | Carrier Heating & Cooling
Thermostat show AUX HEAT
A heatpump has two sources of heat. One is when the heatpump is operating in normal heat mode, and the other is typically electric heat strips.
The strips come on when the unit is going into defrost, when the unit is not able to keep up with the demand for heat (really cold temps) and when the unit is not working properly.
Whne the strips are on, the T-stat displays "aux-heat" to indicate the strips are in operation.
If the strips are working properly you should have warmer air than with the HP alone. Try switchin it from "heat" to "emergency heat" and see what it will do.
When the HP is not able to keep up with the demand for heat then the heat strips come on, but they typically come on only when the room temp has gotten well below the thermostat setting.
In that situation it would be normal to see indoor temps at 63 degrees when the T-stat is set on 70.
But when you set it to E-heat it bypasses the heatpump operation and goes directly to the heat strips. If they are working properly it should maintain an accurate temp in the home.
Jan 23, 2009 | GE Zoneline AZ55H09D Air Conditioner
Heater running continuously
Sounds like you have a problem with your heat pump. Your aux heat is a electric coil. how old is the unit when was the last time it was serviced? How cold is it out side?
Jan 15, 2009 | Honeywell Programmable Thermostat Heater
Haier Energy Star ESA3183 Air Conditioner Logo
1,765 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
