Question about NorStar T7316E Corded Phone
T7316e Phones All lights are blinking
I have a problem with a New Phone that I am trying to hook up to my system and All the lights are blinking and do not stop. Is there a way for me to fix this or is it totally defective????
  • ramsey002 Dec 19, 2007
    All i did was switch one phone from one desk to another (we swapped phones because i moved offices. my original phone cord when i plugged it into the new phone did nothing. The phone didn't even turn on! And the other one started the fast blinking when i plugged it into my new offices telephone cord. Please help!!
  • 31 Answers
Try this first and get back to me. Take that phone, and plug it into an existing extension. If is works correctly, then the problem is in the cabling, programming or that it isn't accessing the system as a digital set. If it continues to blink, then the phone is bad. Please let me know
Posted on May 23, 2007
Message light and charging light blink
your battery is shot. or the connections to charger/phone are bad. time for new phones
Jan 30, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
Why all all Nortel phones blinking and can not call its seems the PBX get damaged?
This is usually an indication of the phone system resetting for some reason. If it doesn't clear try power cycling the phone system for a couple of minutes.
Oct 22, 2013 | NorStar T7316E Corded Phone
Swap M7310 for T7316e? We have M7310 Phones and We would like to use some new T7316e I don't' know what the Phone system is I know they have a couple Analog incoming phone lines and only 7 phones. I see...
Most likely you can swap the phones. On older systems it might not work so I would try one first. You do gain extra buttons which can be programmed as desired. Any buttons you had on your M7310 would be on the T7316e. You can check the buttons by pressing Feature *0 this will allow you to check any button on the phone.
Aug 04, 2013 | NorStar Lands Phones
Why a blinking red light Radio Shack 5.8 GHZ 43-5560 phone
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jul 03, 2013 | Nortel T7316E 2-Line Corded Phone
How do you add a new headset to the T7316e phone. Is there a code that needs to be typed. I have the headset hooked up but the phone reads Need Headset.
No.But you need to do now is take the phone back to where you bought it from and find out wat you will have to do next
Jan 21, 2011 | NorStar T7316E Corded Phone
Im hooking up a nortel system
The Norstar System uses only 1 pair of wire for each telephone. So, use the White/Blue pair.
Apr 28, 2010 | NorStar T7316E Corded Phone
We lost power and when our Meridian M8X24 phone system with T7316E phones came back up we only have access to 2 lines. How do we gain access to the other lines again.
Sounds like your norstar system needs to be reprogrammed because norstar defaults back to only 2 lines when the inturnal battery fails.If the inturnal battery has failed and you reprogram this phone system and you have another power fail you will have to have you system reprogrammed again.Time for new system.
Sep 30, 2009 | NorStar T7316E Corded Phone
Trying to switch the extension number.
On the newer norstar systems the T7208 and lower phones can not be used for programming.The T7316e phone has to be used for programming therefore feature 983 will only work on the T7316e set.To change local dn's you have to go into config programming and to change dn old dn then new dn.
Sep 29, 2009 | NorStar T7208 Corded Phone
I have a T7316e phone set. How do I turn on/off
This would have to be done in system programming. Usually by to vendor that installed the system
Jun 26, 2009 | NorStar T7316E Corded Phone
System startup
Sounds like the power is going off and on in your system or phone. The blinking lights are a boot up sequence. If this happens on just one phone, try changing the line cord, try swapping phones to see if the problem follows a phone or stays at the port. If all phones do this at the same time.... Make sure the power cord is plugged in tightly on your main control unit, maybe change the outlet the system is plugged into. You could also get a UPS battery backup power for a computer and use that to help resolve this problem AND keep your system up and running for short periods in a power outage. If it is not a power issue, there may be a serious problem with your main control unit and you should get a local technician to look at it. If this is a rare occurrence it will be harder to locate.
Aug 24, 2007 | NorStar T7316E Corded Phone
NorStar T7316E Corded Phone Logo
229 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
