Question about Sentry Fireproof Safe
I cannot open my safe.
My sentury safe just has a keypad and i just replaced the batterys on it and it still wont open. when i type in the 5 digit code the red error light blinks and wont open!
im thinking it might be my kids messin with it , I have twins girls that are 3 tears old and they might of been pressing the numbers !
i need to get in there ASAP!
CAN YOU HELP ME?
  • morgan2 Dec 24, 2008
    I have a sentry ac3810 model.
    When I use my five digit combo the green loghtn comes on and the handle will not move. The keyed lock is open this happended before about six months ago after a few days everything was fine.
    Thanks for any help you can provide.
  • 21 Answers
Try holding the # and the * key for 5 seconds that should reset the safe and open it up
Posted on Dec 23, 2008
Need to open a Sentury safe key pad only the batteries died
without knowing the model the best i can doe is link you to you tube and some of the fixes there. i used this search term how to open a sentury safe key pad only batteries died. you may try other terms to get different videos on how to do it. good luck.
https://video.search.yahoo.com/search/video?fr=crmas&p=how+to+open+a+Sentury+safe+key+pad+only+the+batteries+died%3F#id=1&vid=1b6eaea93a88d9929e8b1ce283d04996&action=click
Oct 23, 2017 | The Home Security
Sentry Sage that is key pad no key and the batteries died How do I get in
Oct 23, 2017 | Sentry Home Security
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How do i set code for paragon safe
    INITIAL BATTERY INSTALLATION
    1. Remove the key plate cover, insert the key into the keypad and open the door.
    2. Remove the battery cover plate located on the inside of the door.
    3. Install 4 AA batteries provided and replace the battery cover.
    NOTE
    : If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
    to be changed.
    TO SET UP OR CHANGE A USER CODE
    1. With the door open, locate the red button on the back of the door near the hinge.
    2. Press the red button and listen for the beep.
    3. Immediately enter your new passcode (3-6 digits long)
    4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
    NOTE:
    This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
    first passcode entered.
    SETTING UP OR CHANGING A MANAGER PASSCODE
    1. Open your safe with the passcode you wish to change and leave the door ajar.
    2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
    New user passcodes may be 3-6 digits long.
    3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
    OPENING THE SAFE
    1. Input your code and then press the "B" button, the green light will turn on.
    2. Turn the knob clockwise within 5 seconds to open the door.
    3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
    flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
    CAUTION
    : Entering the incorrect passcode 3 times will lock the system for 20 seconds.
    More information can be found in the attached document web page.
    http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
    Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
    I have a sentry safe model so500 & the batteries are dead, so I can't open it. I know the combination, I just can't open it! HELP!!! thank you, Lesley
    Locksmiths agree on How to install sentury safe batteries
    slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    Aug 07, 2010 | Sentry Fireproof Safe
    Sentry 1610 safe. cannot open. I have been using 5 didgit code for many yaers. All of sudden, it won't open. I see green light after pushing 5 digits. I hear the familar sound. But the handle won't turn.
    there are either 4 AA batteries or in some cases one 9 volt battery that has to be replaced .. in some models you slide off the area under the keypad to get at the battery .. .. as the battery ages it has enough current to operate the display but not enough to operate the unlocking mechinism .. once you have it open make sure the mechinism works freely .. if not it may need some non gumming lub .. dont use WD 40 for this ..
    Sep 19, 2009 | Sentry Fireproof Safe
    Sentry S3807 safe-cannot open
    locksmiths agree on how to install sentury safe batteries
    How do I insert the batteries on my advanced electronic lock safe?
    to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Jan 26, 2009 | Sentry Fireproof Safe
    Sentry Model 1610 Won't Open
    I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
    Mar 29, 2008 | Sentry Fireproof Safe
    Sentury safe Model MSW3517
    HI , I have the Sentry Safe Model # MSW3517. After 10 months of owning this safe the batterys went bad. I replaced the batterys with new ones and the safe still would not open.I checked online and so many people were having the same problem. I called customer service, Who told me to bang on the safe door with a rubber hammer ( What ever are they talking about ) I studied this safe design and found out that the battery holder went bad.Not making a steady contact with new batterys, Went to my local radio shack store and for ( 1.99 $ ) replaced the factory battery holder and now the safe opens with no problems..Very cheap and simple fix.You will have to cut the 9v battery connector plug off the red & black factory wires to connect the new battery holder for this to work.Very easy to do.. goodluck....
    Jan 07, 2008 | Sentry Fireproof Safe
    Sentry Fireproof Safe Logo
    811 people viewed this question
    Top Sentry Home Security Experts
    Hannah Johnson
    Level 1 Expert
    ray012965
    Michael Galve
    Michael Galve
    Are you a Sentry Home Security Expert? Answer questions, earn points and help others
