Question about Polaroid Juke Jam PDP601 (30 GB) MP3 Player
U18 IC While transfering a file from usb the battery run low and i connect charging machine. But instantly an IC burn inside of Juke Jam. I couldn't see the name of IC because of burning. But the number of IC on the PCB is U18. Anyone know how can i find this IC or how can i fix this problem...
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
My i-mate does not start
Hello
you just made a "HimaClearJumpCode.exe" run on ur device(this file exists in ur upgrade folder),and now you are stuck in the bootloader mode
1-hard reset ur device(it wont boot,off course)...
2-plug it in the usb port,u should see that ur system has found a new hardware(if it doesn't,change the USB port)
3-now run the himaupgradeUt.exe.
If this does not work,
1-take the battery off device
2-leave ur device for 12hours without battery,so that backup battery drains...
3-put back the battery,recharge and enter the OS(this option wont work if u have erased the ROM)
4-rerun the upgrade...
The battery might be too low to be charged by the charger,if that is the case;
1) Remove the battery from the phone!
2) Take 3 fresh AAA batteries in series (total 3 x 1.5V = 4.5V)
3) Connect the (+) wire to (+) on the battery
4) Connect the (-) wire to (-) on the battery
5) Hold this in place for 60 seconds.
6) Put the battery in your phone
7) Switch on phone and start charging (via USB)
Apr 14, 2011 | i-mate JAM Pocket PC
My Scooter (Fisher & Paykel - Columbus) Will not charge
Hi. These machines will not charge themselves if the batteries are too flat. The charging system is run by the micro processor IC in the scooter. If the battery voltage is too low the the IC will not have enough voltage to operate.
Remove the batteries from the machine and charge in parallel on a 12 volt charger. Once they are charged, put them back in the machine, and try the scooter on charge again.
Good luck. Neil.
May 15, 2010 | Health & Beauty
Evesham 7211 u18 IC fault
ws-20l is the markings on this IC
As to what it is....that's another story!
Mar 24, 2010 | Evesham Nav-Cam 7700 GPS Receiver
I want to transfer all sate data from my old laptop to my new PC, I have already installed the hardware on the new PC
Sage has an EXPORT function that you can use to transfer data.
You could also copy the daily files from the storage folder to a USB drive
O the new machine use the IMPORT function to import a backup of the files or use the folder options to get data from the USB drive to set up a new company profile which would use your old data to set up a new copy of SAGE with your exisying information.
The prefered option is IMPORT / EXPORT
Feb 21, 2010 | Sage Instant Accounts 8.0 (013604ug)
Transfer digital recording to computer to make CD
As there is no USB port on this IC Recorder, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recorder Software to capture the files. You can also use the Sound Recorder Software preinstalled in the Computer. After transferring the recordings to the Computer, you can use any CD Burning Software to burn the files to a CD.
Feb 19, 2010 | Sony ICD-B5 Digital Voice Recorder
How do I transfer my mp3's from my juke to my pc?
you will need to install the samsung pc suite and transfer them to the pc then to the other phone via the usb cable or bluetooth them.
Jun 06, 2009 | Samsung SCH-U470 Juke Cellular Phone
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
W380 goes blank when connecting via usb in files transfer mode
Finally I got it to work. I had to fully charge my battery as I had noticed that when i was trying before the computer was trying to charge the battery. Once I had fully charged the battery and then attatched it to the computer put it into file transfer mode it was really easy. Anyway I hope you have managed to solve your problem.
Nov 20, 2008 | Sony Ericsson W380i Cellular Phone
Creative Labs Nomad Zen Extra Jukebox 30 GB not working
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer).
If it didn't work out follow these steps:
1. Uninstall Creative Media Source and all related software.
2. Install the driver. In the installation CD the driver is usually in \Drivers\English
3. Turn on the Nomad an connect it to the PC.
4. Install MediaSource(the program requires that you have the nomad connected while installing)
5. Install MediaSource plugin
6. Try transferring files.
If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp.
Jun 14, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Polaroid Juke Jam PDP601 (30 GB) MP3 Player Logo
37 people viewed this question
Top Polaroid Audio Players & Recorders Experts
Mars Nspace
Mars Nspace
Level 1 Expert
Bill Boyd
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
